Re: Ammeter to volt meter conversion
[Re: fastmark]
#2255971
02/19/17 02:00 PM
02/19/17 02:00 PM
Andrewh
[Re: 71rm23]
#2255986
02/19/17 02:30 PM
02/19/17 02:30 PM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
Fastmark-When I had my cluster restored, I had them put in a volt meter and it's a solid state. The only thing I did was take the wires going it, cut the ends, soldered a splice to the red and black, then heat shrink them. Where did you gets the parts?
[Re: fastmark]
#2257041
02/21/17 09:11 AM
02/21/17 09:11 AM
Posts: 2,592 None
71rm23
None
Fastmark-When I had my cluster restored, I had them put in a volt meter and it's a solid state. The only thing I did was take the wires going it, cut the ends, soldered a splice to the red and black, then heat shrink them. Where did you gets the parts? I had the place do it where I sent my cluster into.
[Re: fastmark]
#2257110
02/21/17 12:27 PM
02/21/17 12:27 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I sent my cluster to InstrumentSpecialties. They did the volt meter conversion as part as the resto. I retained the amp meter face however it works as the voltmeter.
Abe Lincoln
[Re: dart4forte]
#2257225
02/21/17 04:24 PM
02/21/17 04:24 PM
Posts: 2,592 None
71rm23
None
I sent my cluster to InstrumentSpecialties. They did the volt meter conversion as part as the resto. I retained the amp meter face however it works as the voltmeter. EXACTLY what I did
[Re: fastmark]
#2257649
02/22/17 09:50 AM
02/22/17 09:50 AM
fastmark
Abilene, Texas
Wow. That's nice. I see a market for that. Let's look at the back side. What volt gauge did you use?
[Re: fastmark]
#2257876
02/22/17 08:11 PM
02/22/17 08:11 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Thanks! I used an Autogauge 2356. Had the decal made up by Whitegauges.net
See this thread on DC.com
http://www.dodgecharger.com/forum/index.php/topic,108698.0.html
1MYTGTX
[Re: Sixpak]
#2259206
02/25/17 12:45 PM
02/25/17 12:45 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I can see adding a volt meter, but don't get why people replace an ammeter with a volt meter. To me, the ammeter is the quickest way to spot a problem with the charging system, or for visualizing which systems, when turned on, are causing a current draw that the charging system can't satisfy... 40 year old wires, loose and cooroded connections, added electrical demand from today's modern electronic ignitions, electric fuel pumps, electric fans, GPS devices plugged into power outlets, aftermarket stereo systems with amps, etc and upgraded alternators putting out double the original amperage.... That's why Lots of cars have suffered electrical fires from under the dash. Even a bone stock car, if you drained the battery and jump it, is now pushing 65 amps through a tiny 10 ga wire that passes through the firewall twice. Bone stock restored car with old points ignition, and fresh clean wire harnesses and good connectors and the stock alternator, then you can go ahead and keep your amp gauge.
**Photobucket sucks**
[Re: 70Cuda383]
#2259210
02/25/17 12:50 PM
02/25/17 12:50 PM
70Cuda383
Marysville, O-H-I-O
Oh, and since it takes the voltage regulator and alternator a second to recover from a large amp draw, and most likely not recover at all from idle, you can see the same information on your voktgage that the amp gauge was telling you. >12? That's the same as slightly over 0 on amp gauge. 12 is 0 and <12 is discharge.
40+ amp load from electric fan kicking on, and a sustained 30 amp draw, at idle you can watch the bolts drop to 10. That's a huge discharge. Blip the throttle to bring RPM up and you can see the bolts come back up, so you know everything is working
