Re: deck finish difference for MLS head gaskets
[Re: Stanton]
#2255796
02/19/17 01:11 AM
02/19/17 01:11 AM
Posts: 2,646 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
In the old days the cutters left little grooves and everyboy said that's fine it helps it grip. Today everybody wants MLS gaskets and Cometic says they want a finish of 50RA or smoother.
2011 Drag Pak Challenger
[Re: Stanton]
#2256029
02/19/17 03:45 PM
02/19/17 03:45 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Use a Fel Pro permatorque composition head gasket Or have the block resurfaced,refinished, for the 50RA finish Copper head gaskets need a fine finish like the MLS head gaskets do
[Re: Stanton]
#2256061
02/19/17 04:32 PM
02/19/17 04:32 PM
Posts: 14 Lewiston, ID.
screemindemon
Lewiston, ID.
I used MLS gaskets on my 416 stroker engine in my drag car, couldn't get them to seal, leaked antifreeze on both sides. Called the manufacturer, was told to re-torque them, which I did, no change. Talked to my engine machinist, he said he had many customers using them and had never had any problems. He also said that different alloys will cut differently, even using the same cutters. You could see the ridge marks on the gaskets when I pulled the heads. Went to Fel-Pro severe duty gaskets, have had no problems whatsoever.
