carter carb id questiony #2255629
02/18/17 08:34 PM
02/18/17 08:34 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
I am going thru some of my late fathers crates in the garage and trying to id what things are. I found 2 carter carbs with id 2999 1406 and 1C39637S. I tried google and came up empty handed for info. Anyone know a site to search or know what these are?
Thanks!
Re: carter carb id questiony [Re: buconine] #2255648
02/18/17 09:16 PM
02/18/17 09:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1406 is an Edelbrock 600 cfm carb, the 9637 is a Carter Competition Series 625 cfm (both are basically the same carb, the Edelbrock being the later version) the other numbers are assembly date codes. Good all around carbs for a stock or mildly warmed over V8. Probably $50.00 $100.00 each core values depending on condition.
Re: carter carb id questiony [Re: buconine] #2255705
02/18/17 11:17 PM
02/18/17 11:17 PM
omahell, ne
buconine Offline OP
buconine  Offline OP
omahell, ne
thanks for the info!
They have been sitting in a crate for at least 30 years, so probably cores at best. Amazing selection of weird stuff he hung onto. Dual coil, dual point distributor, shifters that i have no idea what they fit, pulleys, gears, etc. It's like going thru a time machine!
Re: carter carb id questiony [Re: buconine] #2257921
02/22/17 10:08 PM
02/22/17 10:08 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Those carbs will be fine with a rebuild kit and a good passage cleaning IF they sat with fuel in it. A properly working dual point distributor is a kick ass unit.
