High-quench, reverse-dome pistons look cool
#2255365
02/18/17 03:30 AM
02/18/17 03:30 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I was running a flat top piston in my 493" RB, and with the 76cc chambers in the Indy EZ heads it was near 12.2 to 1 compression. I enjoyed the nearly 7 years I had it on the street. I always burned 101 octane unleaded fuel through it, which was available locally 24/7 at the pump.
I pulled the valve covers for routine inspection, and found bits of the rocker arm bearing cages laying in the heads. I posted that story here a few months back. Turns out valve train harmonics from my hydraulic roller cam and some weak valve springs beat up my exhaust rockers, cracked 3 valve seats and compromised all my valve train parts.
I tore into the motor. In consultation with Dwayne Porter, I upgraded to a mechanical roller, replaced the entire valve train and had him freshen up and repair the heads. Great man to work with by the way!
While it was out, I bit the bullet and dropped the compression to a milder 10.25 to 1 compression, so I could run common 91 octane pump premium. Dwayne was instrumental in helping me spec out the pistons to get the compression where I wanted it.
No one made an off the shelf piston for my combo, so I contacted Ross. They made my previous set, and had the Job Card on file. I gave them the info Dwayne calculated and paid my money.
These 514 gram beauties showed up the other day, and I dropped them off at my local builder. Only recently had I seen a few pictures of what big block Mopar high-quench, reverse-dome pistons look like, so I've attached a few here for your viewing pleasure. I had the skirts coated to reduce friction.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: High-quench, reverse-dome pistons look cool
[Re: Stanton]
#2255468
02/18/17 01:20 PM
02/18/17 01:20 PM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Hmmm ... look like 440Source "off the shelf" items !! Ross used to be the standard 440Source piston. Mine were custom 34cc reverse dome or dish (same thing?) By the time Ross got around to making them 3 months after promised date, Brandon had made them a shelf stock item so he refunded my custom up charge. Kevin
[Re: BSB67]
#2255469
02/18/17 01:22 PM
02/18/17 01:22 PM
jbc426
West Coast, USA
Is that actually a reverse dome, or a flat top with a dish?
Looks nice. It looks like the only difference between the two is that the deck is thicker under the reverse dome on this style of piston. I was told they could not carve a 22cc reverse dome on a standard flat top, as it would leave too little deck thickness.
[Re: Twostick]
#2255470
02/18/17 01:27 PM
02/18/17 01:27 PM
jbc426
West Coast, USA
Hmmm ... look like 440Source "off the shelf" items !! Ross used to be the standard 440Source piston. Mine were custom 34cc reverse dome or dish (same thing?) By the time Ross got around to making them 3 months after promised date, Brandon had made them a shelf stock item so he refunded my custom up charge. Kevin My original flat tops are from 440source. They don't use Ross anymore. In this case, the piston is lighter, has a slightly different compression height, and is larger in diameter to allow for a fresh hone job on the block. The shape of the 22cc reverse dome is also matched to the Indy EZ combustion chamber.
[Re: jbc426]
#2255524
02/18/17 03:52 PM
02/18/17 03:52 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Looks nice. It looks like the only difference between the two is that the deck is thicker under the reverse dome on this style of piston. I was told they could not carve a 22cc reverse dome on a standard flat top, as it would leave too little deck thickness. Yes, of course it is forged to allow adequate thickness. I would still call it a dish. There are pistons out there that actually step-up opposite the spark plug that also have a dish. Those I would call a reverse dome.
[Re: dogdays]
#2258434
02/24/17 12:21 AM
02/24/17 12:21 AM
BSB67
Prospect, PA
The difference between a reverse dome and a dish has to do with the shape of the hollowed out area.
A dished piston top has a round depression, usually centered in the center of the piston. This leaves some of the SQUISH area of the cylinder head uncovered.
A reverse dome has the hollowed out area under the open part of the head's combustion chamber. The squish area of piston and head match, almost exactly. It's called a reverse dome or inverted dome because if the piston had a dome it would go up into the open area. The inverted dome has the piston surface go away from the cylinder head over the open area, just like if you took the dome and turned it upside down.
You can argue that an inverted dome is a dished piston and that is technically correct, but the terminology was developed so you have a better understanding of what the shape of the hole in the top of the piston is.
It's easier to say "inverted dome" than to say "it's a dished piston with the dish mirroring the open part of the combustion chamber."
Semantics.
R. D dish is the term. The Diamond catalog simply calls them dish.
[Re: jbc426]
#2258466
02/24/17 01:17 AM
02/24/17 01:17 AM
Posts: 14,509 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I use the term "inverted dome" for that style piston, which is also how JE catagorizes that design.
[Re: Jeremiah]
#2258510
02/24/17 02:26 AM
02/24/17 02:26 AM
BSB67
Prospect, PA
And they are called dish.
D Dish pistons were available way before anyone even used the words inverted dome, which was developed for building quench in open chamber heads.
There are pistons, I believe Icons, that actually have three different levels, Why, I don't know, but could be called an inverted dome with a dish.
[Re: jbc426]
#2258523
02/24/17 02:50 AM
02/24/17 02:50 AM
fast68plymouth
So. Burlington, Vt.
I'm not a wordsmith, or a piston manufacturer....... But JE, Wiseco, Mahle, SRP, DSS, and CP all refer to pistons that are of the same configuration as what the OP has a picture of as "inverted dome".
The Icon pistons that have the two levels along with the inverted dome, they refer to as a "step dish".
[Re: jbc426]
#2258648
02/24/17 12:32 PM
02/24/17 12:32 PM
Posts: 4,210 New York
polyspheric
New York
Now, think of all those beautifully machined sharp edges surrounding the dish and valve reliefs. They're like little waterfalls, in which the overlap leaving the valve seats near TDC flows. Yes, the flow trips over them, and reduces the effective area of your overlap triangle. If you cam is too small, you're losing power that could be recovered by adding a 1/8" radius to all those edges.
A finished piston may have sharp edges to control flow, but not as shown.
Boffin Emeritus
[Re: dogdays]
#2258752
02/24/17 03:21 PM
02/24/17 03:21 PM
jbc426
West Coast, USA
Semantics.
R. Great explanation!
