Max Wedge Question for Scott Harms or other guru's #225510
02/15/09 12:53 PM
02/15/09 12:53 PM
Wi.
old_racer Offline OP
Wi.
Hi
I'm doing this maxi clone for a friend, how's it look so far? was a 318 ac car so we're using the factory fan shroud and my buddy Bob at Glen Ray did the radiator, had to patch the ac holes on the firewall and put in a regular heater, anyway what is the correct position of the heater hose brackets? tall ones toward the battery or towards the master cyl. I've seen them both ways, also does the negative battery cable go the the exhaust manifold stud? I've seen some guys run it to the wp housing which doesn't look right
thanks
Russ
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225511
02/15/09 12:54 PM
02/15/09 12:54 PM
Wi.
Wi.
another picture
thanks
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225512
02/15/09 01:30 PM
02/15/09 01:30 PM
RUSS FUELfilters WERE OPAQUE PLASTIC, heater hose were in front ,what year is the car?
late 63 batteries were in the trunk , i think cutoff date was around feb.
no single master cylinder?
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225513
02/15/09 01:59 PM
02/15/09 01:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here is mounting location.
Re: Max Wedge Question for Scott Harms or other guru's #225514
02/15/09 02:03 PM
02/15/09 02:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are a few shots of a 63 that might help. If you need repro fuelfilters I can help you. They aren't 100% exact but at least they are plastic and not steel.
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225515
02/15/09 02:04 PM
02/15/09 02:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225516
02/15/09 02:05 PM
02/15/09 02:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225517
02/15/09 02:06 PM
02/15/09 02:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225518
02/15/09 02:10 PM
02/15/09 02:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225519
02/15/09 02:11 PM
02/15/09 02:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225520
02/15/09 02:12 PM
02/15/09 02:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
7.
All of these shots are of 63 cars.
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225521
02/15/09 02:17 PM
02/15/09 02:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No heater hoses yet but a nicely detailed example of what a 63 should look like. This one has 3447 carbs.
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225522
02/15/09 08:01 PM
02/15/09 08:01 PM
Wi.
Wi.
Scott
I've got a bunch of pic's of Doug's car I've sold him a few parts for his project, what a nice guy, what I'm asking is , do the tall hose brackets go to the rear near the master or towards the front by the battery , in your pics one car has them one way and the other has them the other way, did they lift the hoses up to get over the master or lift them up by the battery to get an angle to connect to the motor? this is a 63 plymouth but we have a real 64 intake and carbs, 63 heads tho. my friend lucked out big time , we bought the motor here on Moparts last fall. going to be a fun street car, I feel safer with the steel fuel filters, thanks for your help in advance
Russ
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225523
02/15/09 09:04 PM
02/15/09 09:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sorry, I should have cleared that up. The white car shows the correct positions based on other originals I've seen. This is a 62 car, has them the same way, tall in the rear for brake MC clearance.
Re: Max Wedge Question for Scott Harms or other guru's [Re: ScottSmith_Harms] #225524
02/15/09 09:15 PM
02/15/09 09:15 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I love posts about maxies.
Re: Max Wedge Question for Scott Harms or other guru's [Re: ryangtogtx] #225525
02/16/09 07:48 AM
02/16/09 07:48 AM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Scott
what color where the plug wires and boots on a 63?
Thanks Ed
Re: Max Wedge Question for Scott Harms or other guru's [Re: XXHEMI] #225526
02/16/09 02:47 PM
02/16/09 02:47 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
Here is a 63 sport fury that they are still on, PROBABLY never deen off of.
Mike
Re: Max Wedge Question for Scott Harms or other guru's [Re: rocketresto] #225527
02/16/09 03:01 PM
02/16/09 03:01 PM
Wi.
Wi.
Hi
see this is what I'm talking about , now in this pic the tall one's were on the front.
Russ
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225528
02/16/09 03:24 PM
02/16/09 03:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't doubt them being either way from the factory, but Mikes example is definately the most reliable reference pic posted so far.
Re: Max Wedge Question for Scott Harms or other guru's [Re: old_racer] #225529
02/16/09 06:27 PM
02/16/09 06:27 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
To hijack this post some, I have to say that I want a cross ram in my next car. I know there are better performance options, but I think the cross ram looks so mean, more so thatn the 6-bbl. Nice looking cars here.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
