Please help me identify this power steering pump??? #2255116
02/17/17 06:15 PM
02/17/17 06:15 PM
moparAL Offline OP
moparAL  Offline OP
Please help me identify this PS pump. I believe it is a later Saganaw pump with cooler, off a 440 Police car (75-78). I don't think it is off a small block. Its definately off a Mopar. Can any one varify this??? Would it fit any 383-400-440 motor??? Thanks for any information.
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255142
02/17/17 07:05 PM
02/17/17 07:05 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
Saginaw for sure big block
bracket may be for ac car
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255225
02/17/17 10:59 PM
02/17/17 10:59 PM
moparAL Offline OP
moparAL  Offline OP
What are the differeces in the pumps between air and non air cars. Maybe size of pulley? Offset of pulley? Different high pressure hose?
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255334
02/18/17 02:02 AM
02/18/17 02:02 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I just pulled one off of a 75 440 air car that has the cooler...The pump and bracket looked different as the pulley was farther away from the pump... twocents (1st pic)
I'm not sure why but the brackets on the pump you have sure look like 70 up small block...The slot would rotate from the drivers side bottom bolt on the water pump. nervous
The bottom pic is the pump on my 383 with no AC... shruggy
Definitely different than the one you have... work
...FAFO...
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255348
02/18/17 02:21 AM
02/18/17 02:21 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
That is definitely a Saginaw and I believe those are small block brackets. They look exactly the same as what I have.
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255467
02/18/17 01:18 PM
02/18/17 01:18 PM
moparAL Offline OP
moparAL  Offline OP
This is a later Saginaw with a cooler, OK. Now, is it for a small or big block??? Thanks everybody.
Re: Please help me identify this power steering pump??? [Re: moparAL] #2255731
02/18/17 11:41 PM
02/18/17 11:41 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Yup, small block. You can use that pump though with the proper brackets. Mancini sells them.
http://www.manciniracing.com/bigblsapostp.html
