Re: paint job on a budget!?
[Re: Exit1965]
#22550
04/11/06 01:05 PM
04/11/06 01:05 PM
So has anyone else tried out the penetrol to completion on a test piece?
I have some of that, took back the oderless mineral spirits, and now I am wondering if I should take the penetrol back and get the stinky mineral spirites.
I would test the penetrol myself but I am really gonna only have a small window to use space and doing tests now is not gonna happen for me.
#22551
04/11/06 01:25 PM
04/11/06 01:25 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I dont know if there's a benefit to using penetrol at 9.00 a can. It says it's main use is to allow the paint to flow and level better, but that is what the mineral spirits are for. The penetrol does mention adhesion, but it says that it increases adhesion with primers. And I think if you're using mineral spirits, allowing time to dry between coats, and using thin coats, adhesion is not a concern anyways.
Im not saying it would hurt, but I don't know of a benefit of it over mineral spirits for this.
[Re: Exit1965]
#22552
04/11/06 01:27 PM
04/11/06 01:27 PM
Posts: 141 Columbus
Q5RR
Columbus
Trying to match Q5 (seafoam green or bright turquoise metallic), I bought a quart of turquoise rustoleum at HD using the masstone tintbase last week. It is close but a little too dark. Is there much difference in the color of the two tint bases? If they can custom match your sample using Glidden, and the tint bases are the same color, why not have them tint a quart of rustoleum using the Glidden formula. It might be worth a try. Chris
1969 Road Runner, Q5 Seafoam Turquoise Metallic, M6S(pewter, GTX type) interior. Currently has a 440 with 727 transmission. Numbers matching 383 is now being stored. Looking for a 400 or another 383, located near Columbus, to build in its place.
[Re: Q5RR]
#22553
04/11/06 03:42 PM
04/11/06 03:42 PM
Q5RR, Let us know how that turquoise Rustoleum works out. I'm thinking about going down to HD in the next couple of days to pick up a gallon tinted the same color to paint my '66 Mustang (original color is 'Tahoe Turquoise').
- Ian
[Re: MikeP]
#22555
04/11/06 03:54 PM
04/11/06 03:54 PM
Exit1965
Rancho Cordova, CA
Called my home depot and they DO have this glidden alkyd gloss in gallons and quarts, tintable.
How accurate can they do a color match ? I assume by eyeballing a color chip correct? (no spectro photometer)(color eye)
I dont know about home depot, but walmart has a little eye they put a chip up to, and it matches. I assume hope depot has at least that.
With the glidden, I worry about the yellowing it talks about. I see on some sites that all oil based/alkyd enamels will yellow without light, so if true, the rustoleum would do that too. Can't find info on what "without light" means in terms of how much light it needs, but I haven't found any info on rustoleum yellowing either..
#22556
04/11/06 04:08 PM
04/11/06 04:08 PM
Posts: 141 Columbus
Q5RR
Columbus
- Ian
I just did a small test panel on the RR hood (it will be a sheet metal donor later this summer. I sanded the current paint with a 180 sanding pad, went to 320 and then 600. Cleaned it with paint thinner and used what I guestimated to be 20% penetrol. The coat had lots of bubbles but they worked out and disappeared when I put no pressure and just used the weight of the roller to smooth it.
After that small area was done, I dumped more Penetrol into the tray ( unkown % mixture maybe 50/50). it was fairly watery. It laid down a little better and bubbles smoothed over quicker.
I will let it dry, do one more coat and post some pictures. In the can the color is dark but it lightened up when spread. It may darken as it dries or with more coats, but I hope not.
Chris
[Re: Exit1965]
#22558
04/12/06 05:10 PM
04/12/06 05:10 PM
#22559
04/12/06 05:49 PM
04/12/06 05:49 PM
Exit1965
Rancho Cordova, CA
Ok, guys i've decided to paint my car GLOSS WHITE NOW, the buddha civic that is. My question is, do i need to wetsand the whole car to its original paint to do the new gloss white or can i just paint it over the gray rust-oleum i was using, I have the whole car wetsanded now and am bout to test paint the hood with this gloss white.
At long as the surface is flat, and the grey paint has completely dried (passes the scratch test!) then I dont see why you couldn't put white over the grey. Keep it thin, let it dry and you should be OK.
[Re: Exit1965]
#22560
04/12/06 08:53 PM
04/12/06 08:53 PM
Anyone paint something complex like a bumper with lots of holes for air/bumper lights/etc.? I am also wondering about the grill.
I bought some in a spraycan but I wonder if it will last like the stuff in quarts.
My experience with rattlecan jobs (did my car with 7 cans of bbq paint) is that over some time it will fade, chip easy, and is subject to being eaten alive by road salt.
#22561
04/12/06 09:50 PM
04/12/06 09:50 PM
they should be the same thing. But you can spray the stuff in the quarts can if you had the equipment and thinned it enough.
[Re: 69chargeryeehaa]
#22565
04/13/06 04:39 PM
04/13/06 04:39 PM
on alluminum wheels i used tremclad silver wheel paint in a spray can, just sand the wheels until really smooth and then spray it on, worked great on a old oldsmobile i had. depends on the finish you're looking for, that machined look you cannot do, but just silver paint, use the wheel paint.
The tremclad silver is a different product than the other tremclads, its the only one thats formulated to go onto aluminum/topcoat itself (it contains actual aluminum in it, though with excessive touching the pigment comes out. and you'r not supposed to topcoat with clear or anythign because of the aluminum in the paint it wont bond properly (I was gonna use that paint on my car, but looked into it and no such luck)
#22566
04/13/06 04:43 PM
04/13/06 04:43 PM
#22567
04/13/06 09:57 PM
04/13/06 09:57 PM
Hey. Do as JEFFS says. It works. I would appreciate anyone out there to tell me how to post the pics. of my results. I have a digital camera, the right c.d. on my computer etc. but can't seem to post. Please bear with me as I am a computer idiot, and my 15 year old wiz has better things to do. The easier the better for me. Thanks
#22568
04/13/06 10:28 PM
04/13/06 10:28 PM
Hi guys! Not sure how I stumbled on to this thread but I like it. I have been following since the 19th page and actually started preping my car myself That same day I went to Maccos after work and arrived at 5pm... and they were just leaving so I couldnt get an estimate.. I got an estimate before for 1700$+ .. which I was ready to spend 2k easy... and 3k if I had to :-s Blah.. so that is my story.. been following you guys through the ups- like Exit's first test and the downs- like Exit's "scratch tests" - and then the ups again.. I figure I will just join now so my name gets here so I dont seem like a quick flash of news when I finish my car. I have an '89 Camaro IROC Z28. I sanded it down. The paint was bad.. very bad. Rust, oxidization, peeling clearcoat, chips, etc. I also had dents in the metal and cracks in my lights and plastics and fiberglass. Got 95% of it fixed. I need a few more "touch ups" before I will be satisfied enough to paint. I primed it yesterday because I had a lot of bare metal after sanding it down to get a smooth surface. I haven't done this stuff before but it is a fun experience. Like I said I have been working on my car since page 19 and DAMN is it so much work!! Just removing the ground fx and stuff was a pain!! I spent way more than 50$.. maybe around 200 at least. That is because I had to buy tools Seems like everytime I would buy a socket set the next bolt I would need to take off would need a different type of socket not in my set -_- I have been listing to the mantra that "prep work is everything".. so I have been putting a lot of effort into the prep work. My car is pretty much smooth as glass right now. I went and got my paint mixed at homedepot today. I got the "Gardenia" color- since they don't color match It is a close match to my original paint but not perfect. It is close enough for me though. I have one more bondo fix on my car before I paint it and some light sanding to smooth things out a little more- Then I can paint. I am doing everything outside in an apartment complex parking lot and that has been problematic but surprisingly a lot of people stop and chat with me and say good things. No one has complained to me yet.... it really suprises me because whoever parks next to me gets their car looking like a powder sugar covered donut after I am done sanding. ... but I do wipe down their cars.. and if I make it too messy I'll pay for a carwash for 'em. Anyway- just waiting for good weather before I can paint. I dont want to paint in the parkinglot though. There is a covered garage at the HD and the bottom level isn't really used. I Primed my car there. I think I will go hide there and paint when the time comes Priming a car with spraypaint cans is easier to explain than rolling a car with can of paint Ok, Cheers.. I have TONS of pictures of before and current progress- and have 1TB of webspace and 2TB of BW.. so if any videos need to be hosted I can do it. -Serpent
#22569
04/13/06 10:41 PM
04/13/06 10:41 PM
To add a picture you can attach it to your post. Just make sure that the "I want to preview my post and/or attach a file" box is checked and then when you submit the next page will show a preview of your message and there will be a "browse" button that you can click to search for the image you want to attach. If your image is already on your PC just navigate to the directory that the image is stored at and click the [ok] button. If the image isn't on your computer yet- but on your camera- that will involve a few more steps. Mainly it would require you to connect your camera to the computer or take out the memory card and stick it in a card reader which you should connect to the computer- Either way you would navigate to the directory that the image is stored at and select it. If you give a deeper explination of why you can't seem to post the image here I am sure someone will have a good fix for you.
Cheers, -Serpent
P.S. There is a limit on the file size
