Std. vs Hp cam bearings ?
#2255046
02/17/17 03:04 PM
02/17/17 03:04 PM
Posts: 1,237 North Central, Indiana
Roughbird72
At what point should one go from std to hp cam bearings? Spring pressure, etc... ? Thanks
72 Plymouth Roadrunner 11.08@123.25
Re: Std. vs Hp cam bearings ?
[Re: Roughbird72]
#2255071
02/17/17 04:02 PM
02/17/17 04:02 PM
Roughbird72
Yep, I've had to knife cam bearings before. I was just curious as to what performance level would require an hp bearing.
[Re: Roughbird72]
#2255076
02/17/17 04:11 PM
02/17/17 04:11 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I've used two sets of Durabond "Chilled" cam bearings in BB motors, one 4.5 inch bore World wedge block with B1 heads with a big solid roller cam and the other went into my latest 400 block stroker race motor. Both sets of heads have over 300 lbs. on the seats and over 800 lbs. over the nose My 400 motor and the B1 motor will rotate over a bunch easier with the plugs out than any other wedge motor I've built with regular cam bearings in them with similar spring pressures Roller cam bearings are suppose to be a bunch better than any standard type babbit cam bearings IHTHs
[Re: Roughbird72]
#2255638
02/18/17 08:49 PM
02/18/17 08:49 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
I had a roller cammed hemi beat the #4 cam bearing out oval once. Now, I use hardened coated bearings on everything for which they are available. For 20 bucks more, why not?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2255729
02/18/17 11:39 PM
02/18/17 11:39 PM
Roughbird72
I had a roller cammed hemi beat the #4 cam bearing out oval once. Now, I use hardened coated bearings on everything for which they are available. For 20 bucks more, why not? Good point!
