Head Studs #225504
02/15/09 12:49 PM
02/15/09 12:49 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Best/easiest way to remove. Also is it better to "bolt" on headers or put new studs and "nut" them on??
Grandma always said I had "hands of gold"!
Re: Head Studs [Re: CHRGR69] #225505
02/15/09 12:52 PM
02/15/09 12:52 PM
Kirkland, Washington
Pacnorthcuda Offline
Simple double nutting the studs should work.
I prefer using studs for the headers if space permits. Then you don't contend with draining antifreeze when you remove headers. Use thread sealant on the studs.
Re: Head Studs [Re: Pacnorthcuda] #225506
02/15/09 01:19 PM
02/15/09 01:19 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Makes perfect sense!
