Inside door plastic #2254606
02/16/17 03:06 PM
02/16/17 03:06 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Where to by the plastic vapor barrier for the inside door?
Re: Inside door plastic [Re: 70 buzz] #2254709
02/16/17 07:27 PM
02/16/17 07:27 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Looking for original style or just any plastic? I've heard vapor barrier used in crawl spaces works if you're not worried about original.
Re: Inside door plastic [Re: 70 buzz] #2254724
02/16/17 08:06 PM
02/16/17 08:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Go to a hardware store and buy a roll of visqueen. Cut to size.
Re: Inside door plastic [Re: burdar] #2254726
02/16/17 08:14 PM
02/16/17 08:14 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Just get the heavy stuff and white caulk
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Inside door plastic [Re: 70 buzz] #2254930
02/17/17 09:53 AM
02/17/17 09:53 AM
robertop Offline
robertop  Offline
I bought a set from a place called REM, but that was in 2009.
Re: Inside door plastic [Re: 70 buzz] #2254941
02/17/17 10:41 AM
02/17/17 10:41 AM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
Re: Inside door plastic [Re: Siba] #2255295
02/18/17 01:03 AM
02/18/17 01:03 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Everything you need to replicate an original is at your local Menards or Home Depot.
Start in the paint department and find the "Heavy" plastic. I think it is 4 mil, but don't exactly remember.
Next, go to the tape isle and grab the black duct tape available. Now head over to the plumbing department and find the plumbers putty. This material rolls into a perfect ribbon as the original to seal the plastic.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
