Lash cap damaged valve tips #2254522
02/16/17 12:54 PM
02/16/17 12:54 PM
the Netherlands
dutchrunner Offline OP
the Netherlands
Always thought lash caps protect your valve tips?
Found 5 (No 1-2-3-4-5) intake valve tips damaged under lash caps.
Tops of all caps are fine and also all rockers.
Looks like the valve tip was too soft and now there is like a pin on the same place as the small hole that's in the lash cap.
Engine is about 7000 miles street driven. Gen 2 hemi with StageV heads and solid roller efi cam. Wide pad rockers and "street springs".
What the xxx happened?
No 6-7-8 are fine.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254524
02/16/17 12:57 PM
02/16/17 12:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Too much lash?
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254545
02/16/17 01:29 PM
02/16/17 01:29 PM
the Netherlands
the Netherlands
Lash is as per cam instructions.
As are the other 3 which are not damaged.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254593
02/16/17 02:42 PM
02/16/17 02:42 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Whose valves? Solid roller I assume. If so, what's the over the nose spring pressure and are you sure you are not going into coil bind? Coil bind really stresses valve train parts especially if the valve tips were not properly heat treated.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254597
02/16/17 02:56 PM
02/16/17 02:56 PM
the Netherlands
the Netherlands
Not sure where the valves came from. Are StageV custom heads Cam specs are known D-1749-13-11/20/13. .659/.631 lift and matching springs. Just trying to find out wat could have caused this. Want to prevent repeat with new valves.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254712
02/16/17 07:33 PM
02/16/17 07:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's not been my experience when running lash caps on the street before. Your description does make me suspect the tip of those valves aren't hard enough, and might also have shown wear from the rocker arms if they didn't have the lash caps.
Not all lash caps have holes in the top. The last time I saw/used Crane's lash caps, they were solid (no "breather" hole).
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254720
02/16/17 07:52 PM
02/16/17 07:52 PM
Washington
madscientist Offline
Washington
I have seen this when the valve train has an issue. It could be not enough spring pressure, too much spring pressure, not enough spring rate, valves too heavy or the big one, push rods that flex, or flex too much.
That will hammer stuff that would not normally ever see damage.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254832
02/17/17 12:03 AM
02/17/17 12:03 AM
I'm going to ASS U ME( whistling) those Stage V heads are Hemiriod heads, correct? If so how high are you revving that rascal? Who set those heads up? Do you know if all the open valve springs pressure are close to the same (+ or- 15 lbs) of each other? work I'm thinking those lash caps (only) are floating off of the tips at the higher RPMs and then hammering them back onto the valve tips to make that impression on them work shruggy
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254894
02/17/17 02:43 AM
02/17/17 02:43 AM
the Netherlands
the Netherlands
My speedshop called the valve supplier where they bought the valves from when we rebuild the engine. He says it's turning the lascaps and this causes them to eat-up the tips. Changing all intake and installing locking lashcaps.
@ Cab_Burge . It's a street engine. average rpm 4000 and max 6000.
@ Madscientist . There all checked for spring pressure and installed height.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2254935
02/17/17 10:02 AM
02/17/17 10:02 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Is that what makes sense to you? Or just what you wanted to hear? I wonder if the lash cap manufacturer would say something different? shruggy
I wonder why only on intakes
Re: Lash cap damaged valve tips [Re: BSB67] #2254969
02/17/17 12:15 PM
02/17/17 12:15 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ive seen this before.
Cam profile are typically more radical on intake side. The valve spring is not keeping the valve under control. Most of us don't have a spintron to test the valvetrain.
You have an unhappy intake valve train. Talk with your cam grinder about your intake lobe profile.
Some things they may tell you may surprise you. Seat pressure and weak springs kill parts. You are getting an early warning. I suspect you have too much valvespring for the lift. Meaning the valvespring is not being cycled properly. If you do not open the valve to .050" from coil bind the spring will dance around. For years we set spring height based on a psi for seat pressure or the manufacturer reccomendation for installed height. PAC has me setting spring height based on full open spring height. Amazing the difference it has made in valvespring life.
I regularly turn 9,000 and get incredible life.
Re: Lash cap damaged valve tips [Re: Leon441] #2255028
02/17/17 02:40 PM
02/17/17 02:40 PM
Boise
Moparteacher Offline
Boise
^^^^^ This right here. I heard the same thing from Jim at Racer Brown.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2255043
02/17/17 03:00 PM
02/17/17 03:00 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
That is good info Leon. i never new thought of that before. Always just set them for seat pressure and mad sure max lift was not coil bind. I am going to give your set up a try on my next set.
Thanks for sharing
Old Geezer Racing
Re: Lash cap damaged valve tips [Re: Leon441] #2255068
02/17/17 03:55 PM
02/17/17 03:55 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
enlightening info, Leon. Now we're learning!! glad I checked in on this thread.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2255241
02/17/17 11:36 PM
02/17/17 11:36 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
kind of figured more of an effect of another cause... just not bright enough to know what to point the finger at. We had W5 mill that cracked the bodies of 4 Comp Cams roller lifters in 50 passes. Changed pushrods and went another direction on lifters, and it never happened again. Figured it was some weird harmonics deal... not like you ever hear of lifters cracking. At least we got lucky changing parts.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2255388
02/18/17 06:16 AM
02/18/17 06:16 AM
the Netherlands
the Netherlands
Thanks for this input. Will forward to speedshop. Cam is based on EFI can in Mr. Nedbal's book. Should be right.
Re: Lash cap damaged valve tips [Re: dutchrunner] #2257971
02/22/17 11:47 PM
02/22/17 11:47 PM
new york
68HEMIRR Offline
68HEMIRR  Offline
new york
Dutch.....are you setting your lash at operating temperature?.....did this with mine when it was on the dyno......when i got home and was cooled off i checked it cold.....mine grew .019.....something to look into
BORN TO BE WILD
Re: Lash cap damaged valve tips [Re: 68HEMIRR] #2257995
02/23/17 12:36 AM
02/23/17 12:36 AM
Did it grow and got wider or did it tighten up when cooled off confused
Re: Lash cap damaged valve tips [Re: dutchrunner] #2258119
02/23/17 11:06 AM
02/23/17 11:06 AM
new york
68HEMIRR Offline
68HEMIRR  Offline
new york
stage v aluminum heads....keith black aluminum block.....hot lash....22 intake...24 exhaust.....cold lash.....003 intake....005 exhaust.....tightened up by .019
BORN TO BE WILD
Re: Lash cap damaged valve tips [Re: dutchrunner] #2258330
02/23/17 09:13 PM
02/23/17 09:13 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Leon has it right. There is nothing wrong with the valves or the lash caps. What IS wrong is something in the valvetrain.
Now while it could be too much spring pressure, it could also be too little for how aggressive the intake lobe is and could actually be trying to "throw" the lifter off the cam......OR it falls out from under the lifter on the backside. This beats the hell out of valvetrain parts. How MUCH lift is of little consequence, it's how aggressive the lobe is.
We have guys on Drag Week with cams over an inch of lift and they live just fine. I just have to slow the lobes down and set the parts up right.
HEMI valvetrain is inherently bad already. Mismatched parts make it horrible
