School me on balancers... #2253489
02/14/17 01:03 PM
02/14/17 01:03 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Are there any "bad" balancers/dampeners to avoid on a BB engine?
I'm in the process of building a new engine, and it will have a new bottom end. Since I'm starting from scratch, I just find it a bad idea to put a new rotating assembly in and use a 45 year old harmonic balancer on it. Using a 45 year old block is bad enough. eek eek
What works, what doesn't, what do I avoid?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: School me on balancers... [Re: OhioMopar] #2253520
02/14/17 02:01 PM
02/14/17 02:01 PM
AndyF Offline
AndyF  Offline
First thing to decide is if you need the factory spacing for the pulleys or not. Once you decide that then you can start shopping. Trick Flow has a nice damper for stock pulley location. ATI has nice racing dampers. BHJ, Chryco, etc. have dampers. Go to Summit Racing and look for dampers, you'll probably find more than 20 different ones.
Re: School me on balancers... [Re: OhioMopar] #2253533
02/14/17 02:24 PM
02/14/17 02:24 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'm trying to stick with a stock pulley layout for now. So there are none to avoid, or none better than others? I'll take a gander at the Trick Flows.
Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: School me on balancers... [Re: OhioMopar] #2253539
02/14/17 02:33 PM
02/14/17 02:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
ATI the best IMO. BHJ is great for the price. Make sure you paint or clear coat the BHJ as it looks nice but won't stay that way very long. They used to use those TCI rattlers on the old Pro Stock program. I never tried one, who wants to hear that?
Re: School me on balancers... [Re: OhioMopar] #2253546
02/14/17 02:46 PM
02/14/17 02:46 PM
an8sec70cuda Offline
I have had good sevice from ATI and Fluidamper. I tried one BHJ damper on a fairly mild 500+ hp 440 and it slipped the outer ring after about 6 months of use. No more BHJ for me.
Only bad thing about ATI is you better spray it w/ clear coat before you put it on. Otherwise you'll barely be able to read the timing marks after a year or so.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: School me on balancers... [Re: OhioMopar] #2253583
02/14/17 04:02 PM
02/14/17 04:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think Pioneer makes stock replacement balancers, depending on which year motor, 1966 or 1965 and earlier have the timing mark located different than the later ones scope The balancer needs to match the timing cover year shruggy
Re: School me on balancers... [Re: an8sec70cuda] #2253585
02/14/17 04:05 PM
02/14/17 04:05 PM
dogdays Offline
dogdays  Offline
The harmonic damper on that Cummins engine Ram truck idling next to you at the stoplight is a Fluidampr. They're not cheap but they work.
Avoid the knockoff fluid dampers.
Pioneer makes a good damper. If you think you're going to be racing, an SFI damper can save you money later.
Your friendly Summit catalog has several different dampers and all I have seen in the catalog are good. PowerBond is a Dayco product, that's top drawer.
For strength you'd like the outer ring to be either steel or nodular iron, sometimes called spheroidized iron.
R.
Re: School me on balancers... [Re: dogdays] #2253602
02/14/17 04:30 PM
02/14/17 04:30 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
From what I have discovered over the years, there are mainly two main designs, one is more effective at lower rpms, the other at higher rpms ( I see that point as 6K), and the amount of time in that range. At what RPM YOUR crank assembly has the most flex/harmonics, is likely based on a multitude of variables, and unless with F1 or OEM testing, you can only approximate with your final choice, which based on in the field use, that guessing must work OK. Good Luck. biggrin twocents
Re: School me on balancers... [Re: OhioMopar] #2253618
02/14/17 05:05 PM
02/14/17 05:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Big difference between a dampener used on a low rpm inline 6 vs. a high rpm V8. If Fluidampnr's were free, I wouldn't have one.
69 GTX 68 Road Runner
Re: School me on balancers... [Re: JERICOGTX] #2253637
02/14/17 05:45 PM
02/14/17 05:45 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
What's wrong with them? I have 3 on 720 horsepower plus Motors. I have 2 on 950 horsepower plus Motors. 4 of them I have had over 25 years. Never a problem. Are they going to ruin my Motors? confused
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: School me on balancers... [Re: OhioMopar] #2253659
02/14/17 06:53 PM
02/14/17 06:53 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a Pioneer damper from Jeg's. It's their house brand,but made by Pioneer. It fit well and the pulleys lined right up. Plus it's SFI certified,and wasn't expensive.
Nautilus Racing-
Re: School me on balancers... [Re: Old School] #2253664
02/14/17 06:59 PM
02/14/17 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not a damn thing... I have 2 of them on engines
and been turning 8200 rpm for years.. I just put
a third one on my 416 but thats only a 7200 rpm
engine
wave
Re: School me on balancers... [Re: MR_P_BODY] #2253670
02/14/17 07:11 PM
02/14/17 07:11 PM
Canada
RobR Offline
RobR  Offline
Canada
Innovators West..
Re: School me on balancers... [Re: RobR] #2253683
02/14/17 07:56 PM
02/14/17 07:56 PM
Washington
madscientist Offline
Washington
Originally Posted By RobR
Innovators West..
Is the IW damper a copy of the Fischer damper? I could call and ask, but seems that's what it is.
I've been using FD's since 1990 after a very poor discussion with ATI.
Re: School me on balancers... [Re: MR_P_BODY] #2253691
02/14/17 08:32 PM
02/14/17 08:32 PM
AndyF Offline
AndyF  Offline
I use ATI on race motors since the MSD trigger wheels fit on them. I've run a Fluidamper on my street motor for a long time. Mine is an old one with a flat face that requires a Hemi pulley to get the alignment correct.
If I had to buy a new damper for a street motor these days I'd probably use the Trick Flow one. For a race engine I would use ATI.
Re: School me on balancers... [Re: AndyF] #2253712
02/14/17 09:31 PM
02/14/17 09:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
My preference
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: School me on balancers... [Re: Chris2581] #2253722
02/14/17 09:55 PM
02/14/17 09:55 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Had a Pioneer on my last street wedge. Slipped the ring within 1,000 miles. No warranty coverage, either. Have a BHJ on the Hemi now. 1,200 miles and counting.........
Master, again and still
Re: School me on balancers... [Re: OhioMopar] #2253726
02/14/17 10:01 PM
02/14/17 10:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my mild street car that see's the track only about once a year lately I have used this Pro Sport balancer I bought from Mancini. I have used them on three different street engines with no failures at all. I like that all my stock pulleys line up and it is SFI approved. I have had one on my 63 since 2008 and I drive it alot on the street. The ones I bought were all made in Austrailia. Ron
http://www.manciniracing.com/prosport1.html
Re: School me on balancers... [Re: OhioMopar] #2253799
02/14/17 11:59 PM
02/14/17 11:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Dampers are one of those things I hear people say you shouldn't scrimp on, but how often do you see a damper cause a problem? I suppose the more RPM's a motor sees, the more you need to consider this piece (??). My 451 sees 6400, and I've never had a problem with this one:
https://www.summitracing.com/parts/pfs-80013/overview/
popcorn
Re: School me on balancers... [Re: RobR] #2253860
02/15/17 01:19 AM
02/15/17 01:19 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Innovators West..
X3
Photobucket sucks
