68 charger front brake conversion #225333
02/15/09 09:56 AM
02/15/09 09:56 AM
norton mass
scotman1955 Offline OP
norton mass
when doing conversion i have spindles from a 75 dart what ball joints do i use 75 dart or 68 charger ??? thanks
Re: 68 charger front brake conversion [Re: scotman1955] #225334
02/15/09 10:41 AM
02/15/09 10:41 AM
If those 2 applications use different part #'s you'd want the ones for the 68 charger.
Re: 68 charger front brake conversion [Re: scotman1955] #225335
02/15/09 10:48 AM
02/15/09 10:48 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I left the Charger A arms and just bolted up the spindles. The Charger Ball Joint is fine.
