Header question #2252187
02/12/17 12:32 PM
02/12/17 12:32 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I'm thinking of making a set of headers for my Dart. 408 small block, F2, Indy 360-1 heads, about 1250-1300 horse using a set of 1 7/8" Hedmans. I was looking at using a W2 flange, hopefully that'll seal better then my old set, in 2" then stepping to 2 1/8 and then 2 1/4 with a 4" collector. How far should I go between step ups in the primary tubes? is 4" big enough for the collector? I've got to run exhaust to the rear axle so a set of zoomies is out. I'll most likely use my Hedman Hustlers as a rough guide line. Another member on Moparts did a set similar to this and they look awesome. Any tips or ideas are appreciated.
Re: Header question [Re: 80arrow] #2252285
02/12/17 03:01 PM
02/12/17 03:01 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Find some one who has or download the pipemax program. You can input the engine specs and it will give sizes for primarys in straight,2 and 3 step configurations. Great program to have.
Re: Header question [Re: 80arrow] #2252517
02/12/17 08:19 PM
02/12/17 08:19 PM
oregon
greendart408 Offline
oregon
He has a f2, everything I have read and studied up on says short, and as big as possible, just my findings.
Re: Header question [Re: 80arrow] #2252595
02/12/17 10:14 PM
02/12/17 10:14 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Go big. I'd start with 2" or 2-1/8"
Oh yeah.... make 2 sets smile
Re: Header question [Re: 80arrow] #2253157
02/13/17 09:08 PM
02/13/17 09:08 PM
8
80arrow Offline OP
80arrow  Offline OP
Anyone have a set of inner adapter flanges for the W2 headers that would work on my Indys? That you would want to part with?
Re: Header question [Re: 80arrow] #2253355
02/14/17 02:37 AM
02/14/17 02:37 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Definitely go BIG! 2-1/8 to 2-1/4 to 2-3/8, 4-1/2 to 5" collector.
Re: Header question [Re: 80arrow] #2254077
02/15/17 04:21 PM
02/15/17 04:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you need parts contact http://spdexhaust.com/ Best stuff out there
