3 easy steps to replace radiator on PT Cruiser Turbo
#2251863
02/11/17 10:23 PM
02/11/17 10:23 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
Midway through performing this repair I've discovered a simple, trouble-free 3 step solution for radiator replacement on a PT Cruiser Turbo: 1: Have PT Cruiser Turbo towed to dealer. 2: Pay dealer to replace radiator on PT Cruiser Turbo. 3: Drive PT Cruiser Turbo home. Following these simple steps will virtually eliminate stress from skinned knuckles and help you maintain a healthy blood pressure level.
Re: 3 easy steps to replace radiator on PT Cruiser Turbo
[Re: 300by500]
#2251870
02/11/17 10:30 PM
02/11/17 10:30 PM
Posts: 4,848 Memphis
HemiRick
Memphis
replacing a PT radiator isn't that hard, you have to remove it to replace the starter.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Morty426]
#2251899
02/11/17 11:08 PM
02/11/17 11:08 PM
300by500
There is an easier way
1. Have PT Cruiser Turbo hauled away to scrapper Wife's car. She's had two of 'em. Offered to get her a Chrysler 300 or Charger last time around, she wanted another PT Cruiser. Now she's wanting a Hummer H2.
[Re: 300by500]
#2251935
02/11/17 11:55 PM
02/11/17 11:55 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
No way do you have to R&R the rad to change starter.I can change them without even removing the brace under it.if i was a bit younger i might be able to do it all from the top.Last one i did on the wifes took all of 20 minutes.that was in the drive.Of course I have my tools from 30 years as a wrench.Rocky
Chrysler Firepower
[Re: 300by500]
#2251998
02/12/17 01:07 AM
02/12/17 01:07 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
1. Have PT Cruiser Turbo hauled away to scrapper Wife's car. She's had two of 'em. Offered to get her a Chrysler 300 or Charger last time around, she wanted another PT Cruiser. Now she's wanting a Hummer H2. Sounds like things are going from bad to worse
[Re: therocks]
#2252012
02/12/17 01:30 AM
02/12/17 01:30 AM
HemiRick
Memphis
The only PT starter Ive replaced the car also needed a radiator so I did it from the top....and from the top it has to come out. I have not tried to do a PT starter from the bottom.
