6pak torque converter id #2251823
02/11/17 08:50 PM
02/11/17 08:50 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
73 440 out of a motor home.Steel crank 6 Pak rods.Is thus the correctly balanced converter?Is it a high stall?
Re: 6pak torque converter id [Re: chargers777] #2252077
02/12/17 05:45 AM
02/12/17 05:45 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Did it come off the engine in question? I know that the 6pak bottom ends are externally balanced, so I am assuming that converter would work. I wouldn't think that they would have used a high stall converter in a motor home though. Does it have any markings or numbers on it?
Re: 6pak torque converter id [Re: chargers777] #2252129
02/12/17 10:38 AM
02/12/17 10:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Some steel crank truck motors in those years had the big "six pack" rods but they had lower compression pistons so the were internally balance with a std balanced thin harmonic balancer. Do you have acces to it?
Re: 6pak torque converter id [Re: fastmark] #2252336
02/12/17 04:08 PM
02/12/17 04:08 PM
Alberta
440_Offroader Offline
Alberta
Not a torque converter expert, but the ring gear dimension looks wider than a normal 12" converter. That one may be an 11", which may have a higher stall? Doesn't seem right for a motor home application though. Different externally balanced torque converters will have different weights (eg. 360 vs 440). I think TCS Products has a page with the dimensions of certain weights and their application.
Re: 6pak torque converter id [Re: 440_Offroader] #2253623
02/14/17 05:10 PM
02/14/17 05:10 PM
Nashport, OH
Nashport, OH
Not sure if it is off that motor.anyone have pics of a 440 cast crank converter with balance weights.
