Tuneing through gas tempd. on e-85 #2251520
02/11/17 12:11 PM
02/11/17 12:11 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone here does it? If so what tuning instruments you use?
I was considering this: http://www.ifamilysoftware.com/8525.html
has anyone use these what or the pro's/con's of this work
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251540
02/11/17 12:52 PM
02/11/17 12:52 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Cool little gadgets.. I have found it's best to jet for mph
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251683
02/11/17 04:24 PM
02/11/17 04:24 PM
EGT have been used for years for fuel tuning, especially on gasoline powered airplanes up
My airplane had a single probe EGT, some have two and some have one for each cylinder that displayed all of them on the same screen up
Mine had a single gauge that did not read low exhaust temps. below 900 F shruggy I was taught in flight training to lean it down in flight once I was above 3000 ft. slowly until it reached peak EGT and then richen it up to 25 F to 75 F rich of peak, depending on the brand of motor and if it was normal induction or turbo charged, you would run the turbo charged engines lean of peak by 25 to 50 F shock shruggy
On the rental airplanes that did not have the EGT you could do the same thing on leaning them down in flight by leaning it down slowly until it started to miss or run rough and them turn the mixture control in 1/4 to 1/2 turn up
I got taught the hard way to do that on my second flight in my airplane, I fouled both spark plug out on one cylinder in the second flight shortly after take off about ten miles west climbing from the airport in Bull Head City, AZ and I had left the mixture in at full rich above 3000 FT realcrazy
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251687
02/11/17 04:33 PM
02/11/17 04:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I want to log EGT as well. DIYAutotune has a device that can do 8 EGT sensors and talk directly to a laptop or to an EFI system. From what I have understood using EGT to set up cylinder balance is better than to set it up for power. In my case I am fuel injected and can adjust timing and fuel per cylinder so it would be nice to have.
68 Barracuda Formula S 340
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251696
02/11/17 04:46 PM
02/11/17 04:46 PM
Idaho
LaRoy Engines Offline
Idaho
Exhaust gas temperatures on E85 had me completely baffled. The only time I checked them with our 500" stroker on the dyno, shooting for 8:1 AFR, it went like this...........
12:1 AFR......680 HP......900 degrees EGT
11:1 AFR......760 HP.....1000 degrees EGT
10:1 AFR......845 HP.....1100 degrees EGT....out of dyno time.....seems like it would be pretty hard to blow up an engine on E85
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251813
02/11/17 08:24 PM
02/11/17 08:24 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
LaRoy.......did you happen to record your egt#'s at idle?......Thax for your response up .
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2251886
02/11/17 10:54 PM
02/11/17 10:54 PM
Idaho
Idaho
Sorry, I don't remember and I didn't record them at idle.
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2253414
02/14/17 09:06 AM
02/14/17 09:06 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I'll take a chance and if anyone spray(n20) there car using some sort of egt unit and monitored the gas temps.... work
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254058
02/15/17 03:41 PM
02/15/17 03:41 PM
NY
challenger451ci Offline
NY
When I first starting spraying with E85 I tried to use EGT. There wasn't much info that I could find to even get a baseline so I thought I'd keep it safe by EGT. I chased my tail for a few months before giving up on it. Seemed like no matter what I did with fuel and timing, the EGT would read 1400-1600! That gauge plugs the hole in my dash now and I couldn't even tell you if it works. I found that plugs, time slips and pan vac give a much better picture of what's going on. I also use O2 as another data point, but don't live and die by it. You can chase your tail there too IMHO.
Re: Tuneing through gas tempd. on e-85 [Re: challenger451ci] #2254245
02/15/17 09:52 PM
02/15/17 09:52 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
work Thax you for that info.
challenger 451 you spray a pretty good dose of the nos right?
Do you remember you idle gas temps?
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254287
02/15/17 10:55 PM
02/15/17 10:55 PM
One of the things I had to learn as a instrument rated commercial pilot is that the existing weather has a lot to do with the performance of the airplane and power plants, especially N/A piston engines.
Altitude, both actual and density altitude, as well as outside air temps., barometric pressures and humidity determine how much air the N/A motor can suck in to make heat in the combustion chambers and exhaust pipes work Better conditions, lower altitudes and better tuning make more power and heat in the exhaust work shruggy
E85 and both pure alcohols have considerably less latent heat per gallon than gasoline does shruggy
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254626
02/16/17 03:51 PM
02/16/17 03:51 PM
NY
NY
Just a baby shot. Only a 0.030 jet in a fogger. Idle temps were pretty low, maybe around 700-800? For driveability(idle, part throttle), O2 seems to be a good tool. Certainly more useful than EGT from what I've seen.
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254836
02/17/17 12:14 AM
02/17/17 12:14 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs.... thumbs
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254844
02/17/17 12:39 AM
02/17/17 12:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO leave EGT's to the Methanol and blower guys, or just to make sure that cylinder is working I suppose. Prefer O2's but still read plugs and watch the slip.
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2254919
02/17/17 08:41 AM
02/17/17 08:41 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
what's a good meter that use's a o2 censor that reads e-85 and records the highest temp.?.....Thax for your response fellas up
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2255087
02/17/17 04:31 PM
02/17/17 04:31 PM
I'm not sure which O2 system is best to use on any alcohol based fuel shruggy I do know that you need to buy NTK sensors, the expensive ones for alcohol, for alcohol based O2 systems to get accurate readings thumbs
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2435996
01/16/18 11:24 PM
01/16/18 11:24 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
I just got a egt gauge and am running e85. Curious as to what cylinder I should put the probe in. Thanks.
"I'm not a Gynecologist, but I'll take a look."
Re: Tuneing through gas tempd. on e-85 [Re: Cab_Burge] #2436227
01/17/18 11:58 AM
01/17/18 11:58 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
That's not correct for a NA engine. A regular LSU 4.2 sensor will read down to 4.5 a/f ratio, which is well below the normal 5.5 - 5.2 A/f ratio that is normally seen. Now On a supercharged engine "normal" a/f is 4.2-4.4 a/f.
In addiction, the Daytona sensor wego 5 unit goes down to 3.2 a/f using the lsu 4.2 (Bosch) sensor. ( I have not use this controller)
Also any O2 sensor can be used for just about any hydrocarbon fuels. I have used mine for gas, e85, methanol and diesel. They all output 0-5 volts, it's the Scale factors that are different.
Joe
Without Data, you’re just another guy with an opinion.
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2436238
01/17/18 12:17 PM
01/17/18 12:17 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
this is a copy and paste from a rant on went on about 2 years ago
When I have a engine on my dyno, I DO NOT use EGT’s to tune a engine. I use BSFC and O2 sensors (with ALL fuels) but even with that, I pull the plugs ever time I make a timing change. I use EGT probes to tell fuel distribution and other things, I never use or heavily rely on EGT as A/F Ratio determination
Using the EGT probes for fuel distribution studies is their greatest value.
You can't ask some other racer what EGT is best for you .
example= no matter how well you tune a 9:1 normally
aspirated engine, its EGT's will be higher than a similar
properly tuned engine with 15:1 Compression Ratio .
....no matter what you do , the 9:1 CR engine is going to have
higher EGTs because it will waste heat out exhaust more than
a 15:1 engine, or any CR higher than the 9:1 CR reference point .
If you asked a group of racers that all had their engines
perfectly tuned and maxed out with the best possible ignition
timing curve and A/F Ratio ....
one racer might say 1350 deg F ,
another might say 1250 deg F ,
another might say 1150 deg F,
another might say 1050 deg F
.....they could all be correct and have the very same A/F Ratios
.....the varying EGTs depending primarily upon Compression Ratio,
Volumetric Efficiency percent % , Combustion Chamber/Piston
top design and camshaft design.
Another thing you have to watch out for is
where are you placing the EGT probe??
1-at 12 o'clock or so ...
2-How far away from heads exh port flange ???
3-How deep is the EGT probe protruding into header pipe diameter ????
4-EGT probe type and response time
all these factors greatly influence EGT temps making
it very much impossible to directly compare EGTs between racers
if no standards are set to probe placement
So basically , if you walk around the pits at a National Event
and ask the SS racers that have CR from 9 to 11:1 mostly ,
they'll tell you 1250 to 1350 EGT and maybe a few at 1450
you ask the ProStock and Comp guys with 16+:1 CR
they'll tell you 1000 to 1150 deg F
maybe some of the very large Mountain type engines
with HiCr tell you 850 to 1000 deg F EGTs
Hi Compression Ratio = Lower EGT temps
Lo Compression Ratio = Higher EGT temps
Correct ignition advance(32+ to 40+ ign deg range)= Lower EGT temps
Wrong ignition advance ( below >25 or so deg range)= High EGT temps
..... burn slower and later in stroke , continuing to burn
while exhausting and if severe...cycling/snowballing into rising
coolant temperatures, preignition, then detonation.
bottom line is you need to tune your car by reading plugs and adjusting from there.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2020087
Joe
Re: Tuneing through gas tempd. on e-85 [Re: racerx] #2436289
01/17/18 01:26 PM
01/17/18 01:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After seeing Pettis tune this way I found that I ALWAYS had to jet em back up after a dyno session but this was on gas and prefer afr's........... thumbs
