Re: 1967 GTX tire size
[Re: tweeter1]
#2251610
02/11/17 02:24 PM
02/11/17 02:24 PM
RapidRobert
first would be how wide are your rims?
[Re: tweeter1]
#2251697
02/11/17 04:47 PM
02/11/17 04:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've had a few combos on my Satellite over the years. With stock wheel-wells, my advice is the following: Front: 215-70's on 15x7's Rear: 255-60's on 15x8's with 4-3/4 or 4-1/2 back spacing. This will be tight, but will fit and fill the well. Slicks: you can fit 28x9's on the same rims in there.
[Re: minivan]
#2251763
02/11/17 07:02 PM
02/11/17 07:02 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I had big/little on my '67 Belvedere II '69 4.10 Dana (5/8" wider than '67) Late '70s OEM steel wheels, 15x7" wheels, 4.25" backspace, rear 275-60, front 245-60
After I installed and ran them, I didn't like my choice for the rear for 2 reasons 1- Because of the '69 Dana, the rears were real tight, I had to deflate the tires and let the axle hang to get it in/out of the wheelwell 2- 275-60 will fit on a 7" wide wheel, it would even go on a 6", what it should go on is an 8" wheel, the recommended max for 7" is 255-60
My new setup will be, -original '67 Dana going back in after replacing the original 4.88 with a thin 4.10 -rear tires will be 255-70 on the same 7" steels -fronts will be 215-75 on 15x5.5" steels (from '82 D100) or 205-75 on 5" Am Racing TT Originals
[Re: tweeter1]
#2253608
02/14/17 04:46 PM
02/14/17 04:46 PM
Posts: 4 Bartlett, IL
big_shmoop
Bartlett, IL
Thanks everyone , your pics and comments are all appreciated, Looks like I will go with 60 series instead of the 70's. I don't believe Coker has Redlines in 60 series radials. Guess I will go with TA's. I appreciate all the input and especially the pic's.
Thanks Bob If Coker doesn't have the side you're looking for, try contacting Diamond Back Classic Radials.
'67 Plymouth Satellite
[Re: big_shmoop]
#2253912
02/15/17 03:54 AM
02/15/17 03:54 AM
Posts: 10,160 A Red State
SNK-EYZ
A Red State
Thanks Bob If Coker doesn't have the side you're looking for, try contacting Diamond Back Classic Radials. Exactly. Diamond Back Classics Redlines are what I put on the Satellite. They can make them with T/A Radials or like mine were Cooper tires, just a question of price (T/A's are more $$$$).
