Monte Smith and other chassis gurus #2250502
02/09/17 06:06 PM
02/09/17 06:06 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
You expressed in a recent post that you were just trying to help me... I'm trying to figure out what I should expect as far et out of this car..3020lb 2 speed Powerglide.. 1.87 first gear.4.57 ford 9in out back.28 10.5 slick. Leaf spring
.7in vert 7300 stall. Cast intake sv-1 carburetor burning pump E85.880hp according to Wallace my car should run 5.63 at 123..i have been 5.60 at 123.. with a 1.25 60ft.. what should I expect for a 60 foot with this combination.. I am looking to switch to a 275 Pro... they have to use the environmentally friendly track adhesive here in Southern California.. which I have been told is not very good.. just looking for pointers.. thank you ahead of time
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2250767
02/10/17 12:40 AM
02/10/17 12:40 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
You're definitely on the right track, that car runs good. That 7300 converter has to be fun!
Re: Monte Smith and other chassis gurus [Re: ProSport] #2250835
02/10/17 02:14 AM
02/10/17 02:14 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Those engines do like some rpm Dont they.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Monte Smith and other chassis gurus [Re: ProSport] #2250870
02/10/17 03:54 AM
02/10/17 03:54 AM
bean town ....Ca
W
W
bean town ....Ca
.thanks. it hits pretty soft compared to my 8in. The reaction time does lag with the 7-inch slightly..
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2250995
02/10/17 01:20 PM
02/10/17 01:20 PM
bean town ....Ca
W
W
bean town ....Ca
Also another question is it possible to run radials with a single beadlock.. or will the tire Twist on the rim on one side.. I have zero experience with a drag radial and beadlocks
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251085
02/10/17 04:04 PM
02/10/17 04:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
In a perfect world you would want double, but know a few guys that run single and just glue the inside.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251086
02/10/17 04:06 PM
02/10/17 04:06 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I agree with Brad, I think singles and glue would be sufficient
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251096
02/10/17 04:27 PM
02/10/17 04:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Is the track prep at Fontana WHEN you run conducive to a radial tire?? Just curious on that one. We run a slick and run after the Promod guys, the radial cars are after us. IMO there is likely room for improvement on the 60, which will inturn improve the overall ET obviously. Not talking a ton here either but I am sure if you keep chipping away at it there is a few hun still left in it. I am sure if you talk to Adam the converter could probably be tweaked a bit more, likely more gear can be thrown at it too. I don't think a 4.57 gear is that aggressive for the engine you have, I don't know all the particulars but based on stall speed I would be willing to bet there is improvement with more gear. IIRC you have a Proflite?? There are things that can be done in the valvebody to speed up your reaction times if need be as well. Adam can help you there too.
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251113
02/10/17 04:44 PM
02/10/17 04:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
I'm not trying to hi jack this thread but what is the differences between a single bead lock wheel versus a dual bead lock wheel?
I'm thinking of having one set of my wheels converted to beadlock confused
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251226
02/10/17 08:07 PM
02/10/17 08:07 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Permatex high tack on both sides. Let it tack up for a couple minutes then mount the tire.
Re: Monte Smith and other chassis gurus [Re: Cab_Burge] #2251285
02/10/17 10:02 PM
02/10/17 10:02 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Dual beadlock has locks on the inside and outside of the rim. Single is usually just the outside.
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251323
02/10/17 11:07 PM
02/10/17 11:07 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
While beadlocks look cool and make the tires a snap to change, which are big plus, the locks DO serve a more important function on a small tire car. That is to stiffen the sidewall of the tire. There is not a car out there that likely could not be improved by stiffening the sidewall of the tire. It's not a question of if high tack works( I would NEVER use it on a race car, but that's personal) or if screws work, it's a matter of trying to get all we can in 60ft. Stiffening the tire helps. We run beadlocks AND tubes to this purpose.
To the original question........the car runs well, but I think it should 60ft better. From the questions you have asked before, as well as video, there definitely is more than. As for radials, provided the track is good enough, there could be a lot of ET in the different tire. Not only will it 60 better, but the tire stays "stood up" and doesn't eat ET to nearly the 330 like slicks can. It will 60 better, but the front split will also be much better and both helps the ET.
While we haven't run slicks in a while now, at one time, we were .12-.15 quicker overall on radials than we had ever been on slicks. We have been 2.76 to 330 on radials. High 2.80s on slicks. I have a customer on 29.5s that I have gotten to 1.02-1.04 in 60ft, but it won't touch the Buick at 330. The tire is just that much better.
To go much quicker in 60ft than you are now, two things have to happen. The car has to work and work well and you need good parts. We recently went from one set of $2500 rear shocks, to a different set of $2500 rear shocks. There was a SOLID three numbers in 60ft and this is between two of the best shocks you can buy. From these to not so good shocks, could be nearly a tenth. Some might think it's crazy to spend that for 3 numbers in 60ft. But in this type racing, that's huge. That could be 6- 8 numbers at the stripe. How much would you have to spend on power to get 8 numbers at the stripe.
Re: Monte Smith and other chassis gurus [Re: PC-CHARGER] #2251381
02/11/17 12:58 AM
02/11/17 12:58 AM
Thanks for the help bow up
Re: Monte Smith and other chassis gurus [Re: Al_Alguire] #2251425
02/11/17 02:22 AM
02/11/17 02:22 AM
bean town ....Ca
W
W
bean town ....Ca
Al to answer your question Ultra is considered a radial class.. and typically we run after na 10/5 or after Outlaw 8.5.. the unfortunate thing is there is no place to test that will have radial prep.. I recently purchased 5.0 gears.. and a big book carburetor set up for the Q.. my goal has been a sub 1.20 60 foot.. I guess I will keep my pencil on the drawing board..
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251499
02/11/17 11:19 AM
02/11/17 11:19 AM
Parts unknown
590 Challenger Offline
Parts unknown
I'm with Monte, good shocks seem to be huge for 60'. I only got in 3 passes before the season ended with new shocks. Mine went from a traction nightmare high 1.20s to my 3 passes at 1.17, 1.17, 1.16. On leafs at 3250 with no adjustments at all yet. I can't wait to get out again to hit it harder and see what it can hold.
I found it interesting that Monte says they use tubes to stiffen theirs up more. At what power level does that start to help?
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251564
02/11/17 01:24 PM
02/11/17 01:24 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
590 what shocks are involved in your situation? Leaf spring car?
Re: Monte Smith and other chassis gurus [Re: WHITEDART] #2251622
02/11/17 02:36 PM
02/11/17 02:36 PM
Parts unknown
Parts unknown
Leaf Spring car, Caltracs. I added some Double adjustable Santhuff shocks, clicked them to their suggested radial setting.
Re: Monte Smith and other chassis gurus [Re: Monte_Smith] #2251720
02/11/17 05:36 PM
02/11/17 05:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Provided the track is good enough?
I'm I right in assuming that a poor track will favor a NON radial slick?
I've seen some track on video and it's like fly paper! Up hear that is not the norm.
Matt
Re: Monte Smith and other chassis gurus [Re: MattW] #2251829
02/11/17 09:04 PM
02/11/17 09:04 PM
bean town ....Ca
W
W
bean town ....Ca
I would agree this is our starting line at our local track. They might scrape it once a year. They do not have a drag. And they will use the sweep dry when someone drops oil from the round around track.. and let the drag cars dust it off if you can believe that and it's open every Thursday night and they sell out 250 Tech cards two street cars.. I don't know what real track prep is.. are good track Fontana has a concrete Launchpad and his built in a parking lot that goes uphill
Re: Monte Smith and other chassis gurus [Re: 590 Challenger] #2251955
02/12/17 12:15 AM
02/12/17 12:15 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What shocks did you have before?
