Re: How to repair broken Strato Vent transfer duct
[Re: L.R Helbling]
#2251380
02/11/17 12:58 AM
02/11/17 12:58 AM
Posts: 20,778 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I have repaired broken tabs on plastic grills by getting a scrap piece of the same type of plastic and grinding it into small bits with a rough file and then mixing the shavings into a paste using acetone. Put the paste on in between the two parts and make sure they are stable while it dries. Once it's cured you can sand it smooth and paint over it. It's a very durable repair if you do it right. Scott Smith Harms on here gets the credit for the acetone trick. Do you have the corner piece? If not you may have to make one out of plastic that is the same thickness.
[Re: L.R Helbling]
#2251493
02/11/17 11:00 AM
02/11/17 11:00 AM
Posts: 892 MA
steve70
MA
So does the acetone paste act like a glue for the piece you want to put on?
I need to find a piece of plastic to cut and shape first. I was thinking about an empty laundry detergent jug or perhaps a window washer fluid jug. The vent is made from a kind of waxy plastic often found in large kid's toys. The vent is most likely made from abs plastic so you need to find abs for you repair so the glue will stick. Most molded plastics will be marked as to what they're made of. Most containers like laundry and milk jugs are made from polypropylene or polyethylene. You could buy a piece of abs sheet from Mcmaster-Carr for a few dollars and use it for the missing part. You can shape it with heat to get it close and use abs cement to attach it.
1970 Challenger T/A 4 speed
