Better headlights
#2250827
02/10/17 02:02 AM
02/10/17 02:02 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Are there better headlights available for the 72 RR type of bulbs? I have standard halogens and they arent bad by any means. Put them on relays which helped alot.
But wondering if there is a brighter drop in bulb?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Better headlights
[Re: Von]
#2250863
02/10/17 03:35 AM
02/10/17 03:35 AM
Posts: 1,842 South Bend
John Brown
South Bend
Aircraft landing bulbs, number 4537, but they really suck up the juice, and they are likely to blind oncoming traffic. 200,000 candle power (each), and you will need to adapt to the screw type connections on the back of the bulb. You will also have to file a groove for the alignment lug to orient it in the headlight bucket too. Had them in the bright position on my 69 Catalina and my 70 Datsun pickup. Relays are absolutely necessary. A much more reasonable brightness bulb is the old style Lucas lights, if you can still find them. No doubt they can still be imported from England, but they are probably way overpriced.
[Re: Von]
#2251071
02/10/17 03:42 PM
02/10/17 03:42 PM
Von
NE Oklahoma
I did the relays and wiring per MAD wirings instructions.
The lights are bright, no comparison 2 b4. But, just wondering if there is a brighter lamp to be found.
[Re: Von]
#2251228
02/10/17 08:11 PM
02/10/17 08:11 PM
Von
NE Oklahoma
Well...All I know is the lamps are as bright as some of my more "modern" cars.
Still want to know if better lamps can be found or if I will have to go to Hella type lamps.
[Re: John Brown]
#2251244
02/10/17 08:48 PM
02/10/17 08:48 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Aircraft landing bulbs, number 4537, but they really suck up the juice, and they are likely to blind oncoming traffic. 200,000 candle power (each), and you will need to adapt to the screw type connections on the back of the bulb. You will also have to file a groove for the alignment lug to orient it in the headlight bucket too. Had them in the bright position on my 69 Catalina and my 70 Datsun pickup. Relays are absolutely necessary. A much more reasonable brightness bulb is the old style Lucas lights, if you can still find them. No doubt they can still be imported from England, but they are probably way overpriced. Actually, you can get the Lucas lights pretty reasonably priced. Look up Rogers Motors: http://jollyrogersmotors.com/store/p/423-Lucas-H4-Headlamp-Pair-New.html. These are 7" lights but I am sure they can supply the smaller ones for a 4 headlight system. Very nice people to deal with, just give them a call. We got two pairs of RHD 7" ones for our Landy's, with replaceable Halogen bulbs. I plan to get a pair of the 5-1/2 RHD outboard (low and high) headlights for the Road Runner when I can get it in the shop. Also got relay kits from them with the correct colour coding for the Landys, will see if it matches up to Chrysler colour coding, if not will go with the person on here. The LHD lights are actually $10 cheaper (good for the OP) but we drive on the left here so if spending the money we got the correct ones, the difference is in the lens, both use the same bulb.
[Re: Von]
#2251279
02/10/17 09:48 PM
02/10/17 09:48 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The answer is probably yes with a little footwork. The problem is only that there has been a more limited market for the 4 lamp, 5.75" diameter systems.
If you have a run of the mill Wagner halogen sealed beams, there seems to be some agreement on Candlepower forums (which stays pretty much to evidence based opinions) that the GE Night Hawks are about the best sealed beams out there. So you might try those.
The other option is to change to a good quality seperate bulb and lamp housing system. The Lucas's linked above are that type of system.
For quality - Look for SAE/DOT and/or E-code marked lamp housings. That will assure you the lamp meets a minimum standard; (or rather that the manufacturer certifies it meets the standards.) If available in your sizes (and I think they still are), you can't go too wrong with a Hella's "vision plus" line. Even if its just for the hi/low. These meet both US and European specs and do a great job of putting more light down on the road. Cibie and Bosch also have good lamps of this nature. Not sure about availability in the 5.75" round 4 lamp system like your RR has, but worth investigating. Just make sure you get them for the correct side of the road!
Along with the housings, you'll want good quality bulbs. Poke around on Candlepower forum for which ones. A couple of the Phillips and Narva bulbs seem to be really good with essentially the same current draw as stock and little of expected life.
[Re: Von]
#2251416
02/11/17 02:03 AM
02/11/17 02:03 AM
Mattax
Phila. Pa.
Took a look around on the 'net. Looks like the sealed beam Nighthawk may not be available for the 5.75". According to Virgil's Best headlight for vintage corvair posts (he's a lighting engineer or scientist in real life), photometrics are better on an older NOS quality non-halogen sealed beam than stuff that's available today. For replacing the H5006 (Hi/Lo) the Hella bi-focus mentioned above may be the best option. Hella H4s are also currently available. These listed here are not SAE even though the seller calls them "Vision plus". E-code is perfectly fine nowadays. This used to be an issue especially in states that used mechanical headlight testing. For H5001 replacement (High Beam) there's H1 bulbed Hella's Hella H1 at Summit (pair) or you can buy individually and use the bulb of your choice. I will say that a really good lamp definately makes a difference. Unfortunately there's a lot junk out there and both good and bad stuff is marketed with a ton of hype. It's not just about being brighter, its about getting the light directed in the correct place. One advantage of anything made to meet E-code is that the low beam cuts off so as to reduce glare in rain and fog. Some 5.75" H5006, H4 and H1 Photometrics at Dan SternLighting
