Re: Indy rockers
[Re: rebel]
#225063
02/14/09 09:41 PM
02/14/09 09:41 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Yes, I agree. My opinion, you're already there.
RIP Monte Smith
Re: Indy rockers
[Re: CompWedgeEngines]
#225064
02/14/09 10:05 PM
02/14/09 10:05 PM
I had that kind of spring pressure with the blue 1.6 Indy rockers, The ball end of the pushrods turned blue Very bad oiling!! I had to grind slots from the shaft oil hole to the pushrods in the rockers. Bought a little time. But with that much spring pressure they are Junk. But Indy won't tell you that. I switched to T&D and never looked back.I love them..
Re: Indy rockers
#225065
02/14/09 10:42 PM
02/14/09 10:42 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Just picked up a set of -1's for my car. A good friend has several hundred passes on his Indy rockers (-1 heads) and has not had one break yet. He runs agressive roller cams and shifts in the 7k range. Never broke one yet.
My engine build is very close to his, with slightly different exhaust timing on the cam. With my luck, I didn't want to chance it. I saved up for a little while and bought Harland Sharps from Dram.
I learned my lesson back when I was running small block Fords. I destroyed 3 engines because of valve train failure.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Indy rockers
[Re: GTSDave]
#225066
02/14/09 10:49 PM
02/14/09 10:49 PM
Posts: 268 pa
Kyle Reasbeck
pa
In my experience they're good for about 5 years of racing with those numbers, your spring pressure and lift is VERY close to mine, and i run the 1.6 indy's. I think you'll be fine for a while. I bought 1.6 indys again for ease of install when i broke one on a pass last year, but next time around i'm going to go for t&ds or harland sharps. I'm currently doing some metallography on em to see, but they all break due to fatigue (if you ask around, once one goes, they start to all break successively, and the fracture surface is a typical fatigue fracture), every one i've seen it initiates on the adjuster threads. I could be wrong, but i'm willing to bet they cut tap the threads in instead of roll them, giving a stress concentration and point of failure initiation. If i were you i'd run em for another 150 passes or so then switch to the next level up.
Re: Indy rockers
[Re: drag440]
#225067
02/14/09 11:01 PM
02/14/09 11:01 PM
Posts: 5,875 communist bloc of new jersey
jamesc
What is the limit for these rockers?
do you really want to find out? what else will happen when one fails? lose a money round, lose the engine? imho it's just not worth the agg. been there done that with b1 heads and the "as shipped" rockers. not saying that other rockers don't break or that people haven't used the "as shipped" rockers with some success but normally in the long run the vast majority end up getting a quality set of rockers such a harland sharp, t&d or jesel.
Re: Indy rockers
[Re: jamesc]
#225070
02/15/09 09:48 AM
02/15/09 09:48 AM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
they're not cheap, looks like 67.50 direct from HS. mgiht get them cheaper elsewhere. these for the wife's car?
http://www.harlandsharp.com/bb_mopar_ev_zi.htm
Yes, but we sold the S&W, now we have a 4-link Race Tech. Which ones usually breaks, the int. or exh.? I could run H&S on the exh. This thing is about to break me
Re: Indy rockers
[Re: drag440]
#225071
02/15/09 11:00 AM
02/15/09 11:00 AM
Posts: 16,923 NC
440Jim
NC
Yes, but we sold the S&W, now we have a 4-link Race Tech. ... This thing is about to break me
I guess once Laura ran that fast run, she wants to go faster! Did the old S&W go 7.99? I forgot.
Re: Indy rockers
[Re: drag440]
#225072
02/15/09 11:14 AM
02/15/09 11:14 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I just sold my Indy's, you can get decent money for them. Put some with it and get some Harlands or T&D's. Jack Moore has a great deal on T&D's, I believe around $1050. And Competition Wedge(I think that was his name) has a good deal on Harlands, around $930 if still available.
Re: Indy rockers
[Re: drag440]
#225074
02/15/09 01:22 PM
02/15/09 01:22 PM
CompWedgeEngines
Syracuse,NY
It is not specific to either intakes or exhaust. When you reach a load point and/or fatigue life, it doesnt matter which one it is. The spring pressures are the same, and the offset doesnt seem to really matter. I can show you a bin full of broken ones that were just over stressed. A customer of mine used to run a 451" low deck Indy Maxx with -1's in his S&W digger, and almost exact pressures as you have, just didnt last.Like any rocker, they have there place, but they also have their limits.
Yes you can get intakes only, but as mentioned they arent cheap when you buy them individually. I can certainly help either way with Harland Sharps should you decide to go that route.
RIP Monte Smith
Re: Indy rockers
[Re: 440Jim]
#225075
02/15/09 05:43 PM
02/15/09 05:43 PM
drag440
mopar addict
mopar addict
Keysville, VA
The fastest pass in the S&W was 8.32. This is the same dragster we ran last year and it ran a 8.01. We want to run 7's so I'm swithing from pocket ported SR's and a -2 to -1's and a 3X. I am also going from 1.5 to 1.6 rockers and from a 8896 to a 9377 with a Super Sucker spacer.
Re: Indy rockers
[Re: ProSport]
#225077
02/15/09 07:40 PM
02/15/09 07:40 PM
jamesc
that's what i would do. sell them and put the cash towards a good set. if you could swing it i'd really try to put a whole new set on it. one thing i don't think people are careful enough about with rocker shafts such as the HS shafts are pulling them down evenly. they're hard and don't like to be bent. seen plenty of craks and i attribute it to being bent.
Re: Indy rockers
[Re: 440Jim]
#225078
02/15/09 10:13 PM
02/15/09 10:13 PM
drag440
mopar addict
mopar addict
Keysville, VA
Thanks for refreshing my memory. I thought you two were knocking on the 7.99 door last year. In fact, I think I was at the race she ran a 8.01 or so.
You were, she ran 8.01 at Mopars at MIR. She also went 8.01 at VMP. She doesn't know i'm doing this, I am just going to let her get in it and go down the track and see her face when she comes back around
