Changing speedo gear??? #2249644
02/08/17 12:54 PM
02/08/17 12:54 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
My car came with an original 2.76 gear, as of last weekend it now has a 3.54...anybody know what speedo gear I should now put in to correct the speedometer? The trans is a 904. Thanks up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249646
02/08/17 12:59 PM
02/08/17 12:59 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249649
02/08/17 01:02 PM
02/08/17 01:02 PM
moparx Offline
moparx  Offline
the tech archive at the top of the page has a speedometer gear chart you may find useful also.
beer
Re: Changing speedo gear??? [Re: moparx] #2249658
02/08/17 01:17 PM
02/08/17 01:17 PM
scratchnfotraction Offline
beer
I agree. I used it to figure out the collection of speedo gears I needed for my junk.
yours will depend on tire size but mine are
235/75/15
2.76 = 25 tooth
3.21 = 29 tooth
3.23 = 29 tooth
3.55 = 32 tooth
3.91 = 35 tooth
325/50/15
2.76 = 26
3.23 = 30
3.91 = 36
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249666
02/08/17 01:36 PM
02/08/17 01:36 PM
BDW Offline
BDW  Offline
Re: Changing speedo gear??? [Re: scratchnfotraction] #2249667
02/08/17 01:37 PM
02/08/17 01:37 PM
out in the parking lot put a rear valve stem at 6 o'clock then roll the car forward in a straight line till the stem returns to the same position (grab several bricks & your tape) & measure "rollout" then divide Pi into that number for your diameter then as said go to the chart & CNXT (SP) priorly posted a comprehensive chart that is in the tenths on diameter numbers & your gear ratio. Jack the vehicle way up on the DR side to minimize fluid loss.
Re: Changing speedo gear??? [Re: RapidRobert] #2249686
02/08/17 02:02 PM
02/08/17 02:02 PM
Weatherford, Texas
Weatherford, Texas
Excellent! Not only did I change gears you guys thumped me into remembering that I went from 14" to 15" tires also...sweet! Preferred gear sources?
1968 Plymouth GTX
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249693
02/08/17 02:10 PM
02/08/17 02:10 PM
On Moparts or FABO or Ebay
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249771
02/08/17 04:58 PM
02/08/17 04:58 PM
Ottawa, Ontario
Ottawa, Ontario
eBay.
Re: Changing speedo gear??? [Re: L.R Helbling] #2249836
02/08/17 06:38 PM
02/08/17 06:38 PM
CRT has them in stock. and are a board sponsor.
Re: Changing speedo gear??? [Re: scratchnfotraction] #2249867
02/08/17 07:29 PM
02/08/17 07:29 PM
Weatherford, Texas
Weatherford, Texas
Thanks, and looks like my calculations lead to a 33 tooth gear. up
1968 Plymouth GTX
Re: Changing speedo gear??? [Re: RapidusMaximus] #2249944
02/08/17 09:43 PM
02/08/17 09:43 PM
BDW Offline
BDW  Offline
I'd be surprised if you could get a more accurate diameter by measuring roll out and calculating it than just looking up the tire specs. I'd think manufacturing tolerances are way tighter than trying measure roll out.
If you're going to go to that trouble you're better off taking the tire off and actually measuring it.
Re: Changing speedo gear??? [Re: RapidusMaximus] #2250003
02/08/17 11:28 PM
02/08/17 11:28 PM
Ottawa, Ontario
Ottawa, Ontario
That would be the same one that is on my car. That's the yellow speedo gear part no. 2538933. thumbs
Re: Changing speedo gear??? [Re: L.R Helbling] #2250018
02/08/17 11:39 PM
02/08/17 11:39 PM
I would think that "rollout" would be the most accurate measurement cuz it would be exactly what the # of turns is that will be imparted to the drivetrain & something I remember from drag racers way back is that the tire might even grow some at speed. If you grabbed 2 bricks, your tape and a calculator & have ~8 ft of space in front of your car I think you could knock it out in 5 to 10 minutes. If you do it you might compare it to the tire listed dia & we can see for sure.
Re: Changing speedo gear??? [Re: RapidusMaximus] #2250193
02/09/17 06:50 AM
02/09/17 06:50 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
For one of our math whizzes out there.
Say you have a 275-60-15 inch tire mounted and aired up.
Laying flat on the ground, let's say measures 28 inch diameter.
Now mount the wheel on the car, lower to where is is sitting on the pavement.
As tire will flatten out a bit from the weight of the car, perhaps it is now 27 inches from the pavement to the top of the tire.
How does this effect the rolling circumference of the tire?
If no flattening, 1 full revolution would move the auto 28 inches times pi of 3.1416 equal 88.9 inches.
How far will the car move forward in one revolution allowing for 1 inch less diameter due to this flattening?
Often have wondered about this and how it effects odometer calculations.
Re: Changing speedo gear??? [Re: RapidusMaximus] #2250194
02/09/17 07:05 AM
02/09/17 07:05 AM
A727Tflite Offline
A727Tflite  Offline
Sxrxrnr- the diameter of the tire is not what is needed here - what you need is the "loaded tire radius".
If you measure from the exact center of the axle flange, hub cap, wheel cover - to the ground and do the correct calculations you will end up with the same information without the bricks or moving the vehicle. Either method does not take in to consideration the growth of the tire as speed increases but I doubt that growth is much at speeds less than 70 mph.
Re: Changing speedo gear??? [Re: A727Tflite] #2250222
02/09/17 10:29 AM
02/09/17 10:29 AM
Weatherford, Texas
Weatherford, Texas
Thanks for all the replies guys, appreciate the input, I took the easy way out and used the tire size/gear ratio and just rolled with that. With the current speedo gear being calibrated for 2.76 and 14" tires you can imagine how far the speedometer is off! eek grin
1968 Plymouth GTX
Re: Changing speedo gear??? [Re: RapidusMaximus] #2250224
02/09/17 10:41 AM
02/09/17 10:41 AM
Ottawa, Ontario
Ottawa, Ontario
Rapidus,
Say it ain't so!! You calibrated your speedo gear on 14" tires!!!
No wonder you are way off. shock
Re: Changing speedo gear??? [Re: RapidusMaximus] #2250249
02/09/17 11:44 AM
02/09/17 11:44 AM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
It is easy to calculate exactly the speedometer gear you need but you need to know the axle ratio and the tire size. The previous replies are correct about the importance of using the loaded tire size - also called the rolling diameter. The rolling tire diameter is about 3% smaller than the static (unloaded) diameter.
Tire Dimensions
Tire Upgrades
Re: Changing speedo gear??? [Re: A727Tflite] #2250458
02/09/17 05:11 PM
02/09/17 05:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I disagree. The rollout (which computes to true diameter) will differ from the squatted radius.
