Reading Power Steering Box Date Codes #2250270
02/09/17 12:33 PM
02/09/17 12:33 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
How do you read date codes on power steering boxes? Per the picture below, the date on this box is "9299". So is the correct date the 299th day of 1969, or is it 9-29-1969?
Thanks everyone.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2250445
02/09/17 04:59 PM
02/09/17 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2250474
02/09/17 05:27 PM
02/09/17 05:27 PM
Indianapolis, IN
Indianapolis, IN
Perfect...Thanks, John.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2250718
02/09/17 11:28 PM
02/09/17 11:28 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Rob,
Will that one work for you?
Tom
68 Charger
70 Cuda
Re: Reading Power Steering Box Date Codes [Re: FC7cuda] #2250895
02/10/17 05:33 AM
02/10/17 05:33 AM
Oh
His and Her 69's Offline
Oh
There is also another date stamped into the box elsewhere.
I remember a flat area on mine that was stamped 1019 and that goes along with all the other date stamps on the car. If I remember I will look for a photo.
David
Re: Reading Power Steering Box Date Codes [Re: His and Her 69's] #2250896
02/10/17 05:42 AM
02/10/17 05:42 AM
Oh
Oh
see if this works. In the orange square is where my date stamp is. Hard to see with this photo but it's there. You can see it faintly.
Re: Reading Power Steering Box Date Codes [Re: His and Her 69's] #2250928
02/10/17 10:20 AM
02/10/17 10:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's probably the assembly date
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2250946
02/10/17 11:19 AM
02/10/17 11:19 AM
Indianapolis, IN
Indianapolis, IN
Thanks everyone. I do not see an assembly date stamped into the pad next to the valve outlet on the top of my box.
Tom - I was hoping to find a box with a date in the October range since my car is a B21 SPD. Not sure if you have one that’s a little later.
Which brings me to another question: If a box was cast in Oct-Dec, how did they represent the 2-digit month on the box? It doesn't appear as though there's enough room for a 2-digit month, 2-digit day, and 1-digit year (5 digits total). It looks like they only have room for 4 digits. Did they switch to a letter code for the month, like A289, as an example for Oct 28th 1969?
Rob
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2250960
02/10/17 12:04 PM
02/10/17 12:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Rob,
I think they did it all with numbers. I have plenty of cars to check and have some extra boxes but as usually I'm not home right now.
Chris
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2251022
02/10/17 02:01 PM
02/10/17 02:01 PM
Indianapolis, IN
Indianapolis, IN
Thanks, Chris. If you (or others) could share some pics for what this would look like, that would be really helpful.
Rob
Re: Reading Power Steering Box Date Codes [Re: John_Kunkel] #2252217
02/12/17 01:24 PM
02/12/17 01:24 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Originally Posted By John_Kunkel
Cast 9/29 and probably assembled in 10 or 11/69. What is the OE "acceptable" range for PS pump casting to actual install date?
Tom
68 Charger
70 Cuda
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2252225
02/12/17 01:40 PM
02/12/17 01:40 PM
Indianapolis, IN
Indianapolis, IN
I would say probably 30-60 days in advance of the build. I'm sure this one is within range. For me it's just a preference thing.
Rob
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2253701
02/14/17 09:00 PM
02/14/17 09:00 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I pulled this out of storage and was trying to figure out the date code.This came out of my Cuda.TIA
Re: Reading Power Steering Box Date Codes [Re: 5carguy] #2253871
02/15/17 01:39 AM
02/15/17 01:39 AM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
From my Challenger R/T SE - SPD of 109.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2253952
02/15/17 10:57 AM
02/15/17 10:57 AM
Indianapolis, IN
Indianapolis, IN
5carguy = Based on the logic of reading the casting dates above, it looks like your date is 2-42-7, which obviously doesn't make any sense. That is an interesting date. What is the year and SPD of your Cuda?
RusTy/SE - It appears as though your date is 10-24-9, which makes sense as Oct 24th, 1969. If that's true, it looks like they did squeeze in an extra character for a 2-digit month.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2253954
02/15/17 11:06 AM
02/15/17 11:06 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I have a 71 Cuda SPD Feb 3 Thanks for responding
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2253960
02/15/17 11:32 AM
02/15/17 11:32 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Look at the part number on the box - that's not a 71 part.
Re: Reading Power Steering Box Date Codes [Re: Morty426] #2254014
02/15/17 02:01 PM
02/15/17 02:01 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
That is a box dated the 242nd day of 1977. The box part number is incorrect for a 71 car, it has obviously been changed out. Looks like the dating of these boxes changed between 1971 and 1977.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2254022
02/15/17 02:32 PM
02/15/17 02:32 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I just checked the number and it is for a 73 A Body.Thanks for the replies.
Re: Reading Power Steering Box Date Codes [Re: B5Cuda440-6] #2254078
02/15/17 04:22 PM
02/15/17 04:22 PM
Indianapolis, IN
Indianapolis, IN
I didn't recognize that part number either, but figured it was not 70/71.
