Idle Solenoid #2250344
02/09/17 03:16 PM
02/09/17 03:16 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Has anybody found a less costly after market idle solenoid that could be used on either Hemi, or Six Pack engines?
Re: Idle Solenoid [Re: 71birdJ68] #2250359
02/09/17 03:33 PM
02/09/17 03:33 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I used the Holley switch/bracket on my 340. The pdf file shows part numbers.
Attached PDF document
Re: Idle Solenoid [Re: 71birdJ68] #2250364
02/09/17 03:40 PM
02/09/17 03:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
For functional-only purposes, or something that looks like an OEM part but doesn't cost the same? I don't think even the "cheap" aftermarket replacements from years ago are "cheap" any more, if you're trying to keep the original look.
Re: Idle Solenoid [Re: BradH] #2250606
02/09/17 08:35 PM
02/09/17 08:35 PM
Morristown Tn.
Morristown Tn.
Yes, functionality is the goal. The air cleaner will keep people from seeing that it's not factory.
Re: Idle Solenoid [Re: 71birdJ68] #2250656
02/09/17 09:39 PM
02/09/17 09:39 PM
CA
crackedback Offline
crackedback  Offline
CA
Why not give it a proper idle tune up so you don't need the solenoid?
