Another Steering Box Thread - Small/Large Sector Shaft #2224916
01/01/17 05:16 PM
01/01/17 05:16 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
First I'd like to confirm that a 1972 would have come with a "Small" [1-1/8"] sector shaft, correct? Across the splines on my original box is about 0.030" over 1.125", which makes me ask the question.
Secondly, assuming I had a small sector shaft car, what would it take to upgrade it to the larger 1-1/4"? Is it simply the right box and associated pitman arm from a '73+ Ebody?
Going with the idea that bigger is better with this component.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2224941
01/01/17 05:50 PM
01/01/17 05:50 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
When I bought my box from Firm Feel I got the large shaft with matching quick ratio arms. It was a easy way to upgrade and get firmer steering on top of it.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225016
01/01/17 07:20 PM
01/01/17 07:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
For a ebody or 70-72 B body you can switch large and small spline with the appropriate pitman with no other changes.
Also to consider the price of Moog large diameter pitmans compared to small ones.
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225034
01/01/17 07:45 PM
01/01/17 07:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted By GoodysGotaCuda
eek
With your training, that's not something I would have expected to hear from you, and I suppose you can tell where I stand on the issue. grin
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: jcc] #2225095
01/01/17 09:53 PM
01/01/17 09:53 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
eek
I have sheared off a sector shaft before and twisted one [Jeep], it seems silly to put a smaller, critical , component in at this time.
Past experience is keeping me from trying to nerd-out over this particular topic.
2020 RAM 1500
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225106
01/01/17 10:18 PM
01/01/17 10:18 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
Just don't take your Cuda offroad. work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225110
01/01/17 10:21 PM
01/01/17 10:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You dont measure the splines you measure the shaft.
Mopar to the bone!!!
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225183
01/01/17 11:50 PM
01/01/17 11:50 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Im rooting for you to succeed on the Borgerson unit Goody!
Because if and when you get it all properly functioning, I'm going to blatantly copy your setup haha!
It would be awesome to get rid of another 10-15 pounds off the front end.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2225261
01/02/17 01:22 AM
01/02/17 01:22 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
work
You lost me, but maybe that was the point. grin
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: amxautox] #2225895
01/02/17 09:53 PM
01/02/17 09:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's those 42" tires that will kill it.
biggrin
- Stu Harmon
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2243742
01/30/17 01:12 AM
01/30/17 01:12 AM
Andrewh Offline
Andrewh  Offline
for my 65 coronet, which shares most of the same suspension stuff, that is all I did.
ordered up the newer box, which apparently is the same up to the 89 full size rwd cars and the 73 and up pitman arm and it dropped in.
I was concerned about indexing, but even that lined up the same with no issues.
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: Andrewh] #2245624
02/01/17 11:36 PM
02/01/17 11:36 PM
IN
ahy Offline
ahy  Offline
IN
Per my understanding the larger shaft uses the more common and less expensive pittman. Is the larger shaft better beside cost? IDK. When I had my box rebuilt I chose the larger shaft at no added charge to use the lower cost pittman. I figured the larger diameter was a possible strength bonus despite the slight added weight... and happy with lower cost.
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2249734
02/08/17 03:46 PM
02/08/17 03:46 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I have the larger shaft in my Cuda, seemed to work fine. Now I wonder, why did Chrysler go to larger shafts in 1973?
Re: Another Steering Box Thread - Small/Large Sector Shaft [Re: GoodysGotaCuda] #2251937
02/11/17 11:58 PM
02/11/17 11:58 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Iirc, C bodies had the larger shaft for a few years prior.
Then the B vans came out and they used the same shaft. At that point it may have just become more cost effective to standardize across all platforms.
Angry white pureblood male
