engine paint question #2248747
02/06/17 10:00 PM
02/06/17 10:00 PM
central ohio
mopar rookie Offline OP
central ohio
I know this question has probably been asked a lot on here but... I am doing a 64 max wedge and its time to paint the motor. I wanted to do the whole graveyard cars thing with the primer and all but I guess I will have to use the spray can method instead. Its basically all bare metal. I scuffed up the Milodon pan and it has new aluminum heads and a bare block/intake. Whats the best method? What brand Orange and also do I need to primer. I have a lot of work in the car and don't want the paint to flake off the heads or anything. Thanks, Jan
Re: engine paint question [Re: mopar rookie] #2248812
02/06/17 11:18 PM
02/06/17 11:18 PM
I ain't a painter per se but when I do (at the amateur level that I do) I finish my cleaning by drowning the surfaces with brake kleen to get em surgically clean cuz as we know prep is 90% of the game. Others will chime in
Re: engine paint question [Re: mopar rookie] #2248813
02/06/17 11:21 PM
02/06/17 11:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I like a zinc-rich primer, especially for the aluminum parts. Gotta clean everything & use a wax & grease remover, of course. Max Wedges got the brownish shade of "Hemi Orange", also known as Race Hemi Orange. I think I used the VHT brand on mine but that was a few years ago. Seems every rattle-can brand is a different shade: some yellowish, some reddish.
Everything should be about room temp, so hopefully you're good there.
I've painted my aluminum heads & intakes to match the block for 40 years, and haven't had one peel or flake yet.
Re: engine paint question [Re: mopar rookie] #2248827
02/06/17 11:45 PM
02/06/17 11:45 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not a expert by any means but in my experience those gold color milodon pans need the finish removed otherwise there will be adhesion issues.
Re: engine paint question [Re: topside] #2248832
02/06/17 11:48 PM
02/06/17 11:48 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Get a Preval sprayer from your local hardware store and you can use automotive grade primers and paints.
http://www.preval.com/
If you do use rattle cans beware of possible color variations from one can to the next. It's all too easy to end up with a cylinder head, intake, etc that won't quite match the rest of the engine based on where you were at when you switched to a new can of paint. The Mopar Performance Hemi orange cans I bought many years ago were all over the place.
Re: engine paint question [Re: mopar rookie] #2248860
02/07/17 12:34 AM
02/07/17 12:34 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Plasti Kote makes the best orange engine color for Mopar.
Nautilus Racing-
Re: engine paint question [Re: mopar rookie] #2248875
02/07/17 01:02 AM
02/07/17 01:02 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
POR-15 Hemi Orange
1963 Plymouth Max Wedge
1971 Barracuda
Re: engine paint question [Re: mopar rookie] #2248884
02/07/17 01:18 AM
02/07/17 01:18 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Roger Gibson has the correct Race Hemi Orange in pint cans.
Re: engine paint question [Re: mopar rookie] #2249170
02/07/17 04:53 PM
02/07/17 04:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
He did say he was using rattle cans, which really isn't a problem. Unless one buys the MP cans, which are the worst crap ever.
Re: engine paint question [Re: topside] #2249180
02/07/17 05:06 PM
02/07/17 05:06 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I've got 20+ years on a 440 primed, and rattle-canned with MP street-hemi orange...
It's holding-up real well...
That was when paint was paint...
Re: engine paint question [Re: mopar rookie] #2249214
02/07/17 05:59 PM
02/07/17 05:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I like the eastwoods engine paint with hardener added. A cheap harbor freight paint gun and $50 in paint/hardener and you have a nice finish that immune to solvents/stains from fuel leaks, coolant leaks, oil leaks, etc.
Can't vouch for originality. I wasn't around when these were new, and every car you see at a show looks slightly different. You'd likely need to do a side by side of a good quality survivor to tell
**Photobucket sucks**
Re: engine paint question [Re: mopar rookie] #2249216
02/07/17 06:01 PM
02/07/17 06:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
EK2 body paint (without the metallic) is real close to the Maxwedge engine color Race Hemi Orange. I've never used primer and it stays stuck if the parts are surgically clean.
Re: engine paint question [Re: John_Kunkel] #2249252
02/07/17 07:20 PM
02/07/17 07:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I've used Hirsch paints on all my builds, even works good with a brush! up www.hirschauto.com
JB Rhinehart, Realist
A-Body's RULE!
Re: engine paint question [Re: Rhinodart] #2249314
02/07/17 09:15 PM
02/07/17 09:15 PM
decades ago I remember the "race hemi" MP rattle cans looked like a very close to the normal Chrysler orange and the "street hemi" cans were a pukey yellow/orange tinted paint that looked horrible. I think I am remembering the "names" correctly but I definitely remember that the one that was supposed to be "correct" was not & the other one that was supposed to be for the other app was actually very good (to my untrained eye) for the "regular" orange I was after.
Re: engine paint question [Re: mopar rookie] #2249496
02/08/17 01:54 AM
02/08/17 01:54 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Rattle can paint quality has gone to crap over the years and it wont hold a shine well for over a year now IMHO. Real auto paint is the only way to go if you want a shine that will last.
How long does one of those Preval canisters last? Could you paint and engine with 1, 2 3 or 4?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: engine paint question [Re: HemiRick] #2249510
02/08/17 02:22 AM
02/08/17 02:22 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
2 preval sprayers should be enough to do a whole engine.
Buy one with the spray unit and the glass jar, and a second spray unit. Probably $16.00 +/- for the pair. Once you have the glass jar you can clean it with reducer and reuse it over and over.
I use them for priming small items all the time. Best thing is the air pressure is relatively low so you don't end up with a fog of overspray that gets all over the place.
Re: engine paint question [Re: Neil] #2249516
02/08/17 02:34 AM
02/08/17 02:34 AM
I've heard good on Preval over the years & the price ($16) is dirt cheap. the only thing I could see going wrong is improper surface prep/contamination in your mixing steps/moisture in the hose. EDIT I Googled it & it has its own pressurized cans of propellent so that elims the air hose potential issue
Re: engine paint question [Re: mopar rookie] #2249951
02/08/17 10:05 PM
02/08/17 10:05 PM
central ohio
central ohio
No matter what route I take proper prep is key. I just have never mixed paint before and that was my concern. If i can get the mix figured out the Preval sounds like a possibility. I will keep you all informed and thanks for the advice. I used to be able to just click on brouse to post a pic but that seems to have changed? I may have to get my daughter to help me out there lol
Re: engine paint question [Re: mopar rookie] #2250047
02/09/17 12:09 AM
02/09/17 12:09 AM
I went back to my grade/high school in Kansas where I grew up & the 1st grade school rooms had computers (for the students not the teacher). EDIT here's how high tech I am
Re: engine paint question [Re: RapidRobert] #2250063
02/09/17 12:31 AM
02/09/17 12:31 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Say what you want, but rotary phones are kinda fun to use.
Any auto paint store can help with how to mix the paint. The preval glass jars are graduated so you can use the hash marks to get to the correct ratio of paint, reducer, hardener depending on what you need.
