Page 4 of 5 1 2 3 4 5
Re: Billet valve covers [Re: AndyF] #2195823
11/13/16 05:47 PM
11/13/16 05:47 PM
CA
bbodee Offline
bbodee  Offline
CA
Andy, I think a pair of those clear top valve covers with an interchangeable solid top would be pretty slick. Put the clear on for inspection/ dyno/troubleshooting, (or to show off haha) then swap the solid top on for regular use.
Re: Billet valve covers [Re: AndyF] #2195827
11/13/16 05:55 PM
11/13/16 05:55 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Does the bolt on top clear a distributor or is a belt drive distributor required with those valve covers?
[image][/image]
Re: Billet valve covers [Re: TRENDZ] #2195858
11/13/16 07:05 PM
11/13/16 07:05 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
"..A little known fact about factory heads is that the valve cover bolt holes are not square to the rail. They are all tipped toward the intake side. Also the rail area where the bolts are drilled are also tipped. This means a flat surfaced valve cover will not sit evenly on a factory cast head." quoted from TRENDZ
I discovered that when I put studs in the "452" heads I used on my '64 Polara and tried fitting the Mopar Performance cast valve covers on the engine in the car. I had to slot the holes to make them fit mad
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Billet valve covers [Re: Polarapete] #2248643
02/06/17 06:33 PM
02/06/17 06:33 PM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
It would be great if someone fabricated aluminum valve covers that were tilted the 15*, like the OEM valve covers, for use on cast iron heads. I would buy a set real quick.
Re: Billet valve covers [Re: AndyF] #2248893
02/07/17 01:26 AM
02/07/17 01:26 AM
AndyF Offline OP
AndyF  Offline OP
I made my second gen valve covers with the exhaust side laid over at an angle to provide more clearance for the HP manifolds.
Re: Billet valve covers [Re: AndyF] #2248896
02/07/17 01:27 AM
02/07/17 01:27 AM
AndyF Offline OP
AndyF  Offline OP
Here is another view on the engine.
Re: Billet valve covers [Re: AndyF] #2248915
02/07/17 02:11 AM
02/07/17 02:11 AM
Boise
Boise
Very nice!
Re: Billet valve covers [Re: AndyF] #2248968
02/07/17 05:06 AM
02/07/17 05:06 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Andy, is that plexi glass or lexan or? that you used for the clear top. I have seen some SS semi cars with clear tops. I think Wescott used to make them for Hemis.
Re: Billet valve covers [Re: AndyF] #2249042
02/07/17 12:45 PM
02/07/17 12:45 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
That is purdy
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Billet valve covers [Re: rowin4] #2249080
02/07/17 01:56 PM
02/07/17 01:56 PM
AndyF Offline OP
AndyF  Offline OP
It is clear polycarb. I'm not sure if the shop buys LEXAN or some other brand.
Re: Billet valve covers [Re: AndyF] #2249390
02/07/17 11:21 PM
02/07/17 11:21 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
How heavy are the Big Block valve covers Andy?
Alan Jones
Re: Billet valve covers [Re: AndyF] #2249398
02/07/17 11:38 PM
02/07/17 11:38 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Andy do you sale these valve covers. How can I get a set.
Re: Billet valve covers [Re: AndyF] #2249498
02/08/17 01:56 AM
02/08/17 01:56 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
ANDY
can you make valve cover spacers 1/2 for B1 heads ?
1.39 9.85 - 137 mph
Re: Billet valve covers [Re: HDNMOPERS] #2249508
02/08/17 02:20 AM
02/08/17 02:20 AM
AndyF Offline OP
AndyF  Offline OP
I don't have any for sale right now but I can make more. They cost $1000 per set.
Re: Billet valve covers [Re: LA360] #2249509
02/08/17 02:22 AM
02/08/17 02:22 AM
AndyF Offline OP
AndyF  Offline OP
I haven't weighed them. They are a little heavier than a cast cover. They can be made lighter but it takes more machine time.
Re: Billet valve covers [Re: Ari440] #2249899
02/08/17 08:14 PM
02/08/17 08:14 PM
LA360 Offline
LA360  Offline
Originally Posted By Ari440
ANDY
I can
Alan Jones
Re: Billet valve covers [Re: Ari440] #2249903
02/08/17 08:15 PM
02/08/17 08:15 PM
AndyF Offline OP
AndyF  Offline OP
ANDY
I don't have any B1 dimensions so no I can't make spacers for them. But it isn't very hard to do if you own B1 heads. Just use a set of valve covers as a template to start with. That will probably get you close enough and then go from there. Or call up Koffel and ask them for a drawing so you can get some spacers made.
Re: Billet valve covers [Re: AndyF] #2251674
02/11/17 03:59 PM
02/11/17 03:59 PM
AndyF Offline OP
AndyF  Offline OP
I painted the covers engine color. I prefer the painted look, the shiny billet look just seems to distracting.
Re: Billet valve covers [Re: AndyF] #2251676
02/11/17 04:01 PM
02/11/17 04:01 PM
AndyF Offline OP
AndyF  Offline OP
From what I've seen the new Trick Flow cast covers are going to look a lot like my billet covers. If that is the case then you can save a ton of money by getting the Trick Flow cast covers and milling off the Trick Flow name. Not sure when they are going to be available but I've seen some pictures of them and they look pretty good.
Re: Billet valve covers [Re: LA360] #2976688
10/21/21 01:26 AM
10/21/21 01:26 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Originally Posted by LA360
Originally Posted by Ari440
ANDY
I can
LA360, can you make a set for a small block? I have Trick Flow heads.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
