front end alignment #224892
02/14/09 05:59 PM
02/14/09 05:59 PM
minnesota
P
president61 Offline OP
P
minnesota
whats the easiest and best way to get a front end close enough so I can drive it to the alignment shop? I don't have any special tools. the car is a 67 Coronet thanks
Re: front end alignment [Re: president61] #224893
02/14/09 06:06 PM
02/14/09 06:06 PM
Kirkland, Washington
Pacnorthcuda Offline
Use a level to get the wheel to true vertical (neither neg or pos camber) and make the front of the tires (as high up as can, which might be only about 5:00 o'clock ) equal to the rear of the tire (about 7:00 o'clock) so that you have something close to zero toe.
If your only driving straight to alignment thats way more than adequate
Re: front end alignment [Re: president61] #224894
02/14/09 06:10 PM
02/14/09 06:10 PM
get the tires vertical(at the top) w the cam bolts & w the steering wheel straight ahead, with the tie rods sleeves get the tires pointed straight ahead(on the front of the tires) & snug everything down.
Re: front end alignment [Re: president61] #224895
02/14/09 06:47 PM
02/14/09 06:47 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
What they said - use a level top to bottom on the tires/wheels and twist the upper control arm cam bolts until the tire is level in the vertical plane. Measure between the front tires in the front and back so they are the same distance apart.
