Re: Trans brakes, opinions wanted
[Re: justinp61]
#2248735
02/06/17 09:49 PM
02/06/17 09:49 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
I have not tried one of his, but it would seem, leaving in 2nd is for any car that has too much hp to launch effectively in 1st gear.
What typically comes to mind are those crazy 275 guys running way more hp than I ever thought a set of little tires would hold...or the class that does not allow wheelie bars, which is just nuts...
I can tell you I have accidentally short shifted past 2nd right to 3rd, and it barley kills any ET...Never launched in 2nd though, especially off a trans brake.
Do those have the LBA as well I think? I always wondered, which is faster in the 1/4....The none LBA or the ones with the LBA....
[Re: justinp61]
#2248762
02/06/17 10:20 PM
02/06/17 10:20 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
I could always cut as good a light off the foot as with a brake. I ended up using the brake only when I had to, on a pro tree. That is just me, but I have met plenty of other guys like myself who found things" sped up" and hurried them getting up on the two step the shortest amount of time to not be hard on things and still concentrate on the tree. The foot slows things down for me and makes me more relaxed Brakes are much harder on everything than the foot. Give serious consideration to how much you race, how much you think having a brake will make a difference. And how much extra breakage it might cause. Just my 2 cents... Lol
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Dave Hall]
#2248765
02/06/17 10:23 PM
02/06/17 10:23 PM
B3422W5
Portage,michigan
I have to disagree on the 1st to 3rd thing. Absolutely killed my car but I probably don't make the beans that you do. My car with a powerglide is quicker in 60' than it was with the low gear of the T/F. I don't know if it's just the less reciprocating mass or is it that it takes better advantage of the torque? Seems to me that having a choice of either gear applying the brake could only be an advantage along with a clean neutral. I have went first to third( several time on purpose, several times by accident) on a high 9 sec car. Pretty consistently knocked 2 tenths out of it.
