84cc head to a 78cc head
#2248401
02/06/17 12:51 PM
02/06/17 12:51 PM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
How much is my comp ratio going to change going from a 84cc head to a 78cc head thanks in advance
75 duster 440 in the works
71 pro street cuda
Re: 84cc head to a 78cc head
[Re: 1fastaspen]
#2248439
02/06/17 01:40 PM
02/06/17 01:40 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Go to the Wallace calculator site and plug in your info
[Re: 1fastaspen]
#2248478
02/06/17 02:30 PM
02/06/17 02:30 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
well less than a full point.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 1fastaspen]
#2248565
02/06/17 04:10 PM
02/06/17 04:10 PM
B3422W5
Portage,michigan
Can't see it being more than a point on a 10 something compression engine with only a 6cc difference. More like probably a little more than 1/2 a point. It isn't a big difference
[Re: 1fastaspen]
#2248651
02/06/17 06:51 PM
02/06/17 06:51 PM
fast68plymouth
So. Burlington, Vt.
On a stock stroke 440, +.030, where the starting cr is 10.75......... Lowering the volume at tdc by 6cc's(chamber volume goes from 84 to 78), changes the cr .66........ So, 10.75 would end up at 11.41.
It just happens to work out that on stock stroke 10:1 440, 1cc is worth about a tenth of a point of compression.
[Re: 1fastaspen]
#2248688
02/06/17 08:27 PM
02/06/17 08:27 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
It's goes from 10.75 to 11.8 Are you really at 10.75 comp now with a 84cc chamber? You must have domes then. A 6cc smaller chamber on a 440 from a 10.75 comp will be 11.43 A flat top 0 deck, 4.32 bore 440 will be 10.158 comp with 5cc valve reliefs and a .038 gasket, {With a 84cc Chamber.}
[Re: 1fastaspen]
#2248903
02/07/17 01:40 AM
02/07/17 01:40 AM
Posts: 635 mississippi
bentwheel43
mississippi
I bought some RPMs84cc they was 82cc(on the box)I had them milled .040 got 75cc and I wish I wouldn't have. Now mite have to mill again one day. time dose it. I don't think that's the best place to look for horsepower.
Section 8 Racing We are nuts about racing.
