9" rear axle questions........
#2248212
02/06/17 01:23 AM
02/06/17 01:23 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I know I am not supposed to be running a Ford rear under my D50 but that is what is under it. I broke a axle the last time I was at the track and I need to figure out what spline to go with. I was running after market 28 spline. I need to upgrade, what spline count would you run 30,31,33 or 35. I only have about a month to get back track ready.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 9" rear axle questions........
[Re: D-50]
#2248268
02/06/17 02:29 AM
02/06/17 02:29 AM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
If you have to buy axles and spool anyway, go to 35 and be done.
[Re: Dave Hall]
#2248301
02/06/17 04:16 AM
02/06/17 04:16 AM
Posts: 6,145 Melbourne , Australia
LA360
Just be aware that 35 spline will require a 3.25" bore case. If you have a 3.062" bore case, you can either run 33 spline axles, or go with a Mark Williams spool. The spool is longer, so your axles will be slightly shorter. The other option will be searching through the Timken catalogue and finding a different bearing.
Secondly, do you have the large or small axle bearing? Small bearing will require new housing ends
Alan Jones
[Re: LA360]
#2248314
02/06/17 07:58 AM
02/06/17 07:58 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Secondly, do you have the large or small axle bearing? Small bearing will require new housing ends Just went through this after a mate broke his 31 spline locker . Though you can get a 33 or i think also a 35 into a 3.0 case you will shortly after break the case as the bearing is so narrow/small . Sell your current centre and upgrade while you can sell it . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
