Re: Bought my first 400 Block this Weekend
[Re: Dragula]
#2248243
02/06/17 02:03 AM
02/06/17 02:03 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
My old 400 block pump gas stroker motor made the most power with a set of 440-1 CNC ported by Jeff at MCH I tested two different motors with those heads and a set of Indy SR M.W. intake ports, the SR flowed 30 CFM less than the -1 did and the -1 heads made over 50 HP more than the SR heads did on the pump gas motor they made 65 more HP on the race gas motor Same short blocks, cams, intake and carb with no jetting or timing testing on either motor Go big for big power
[Re: Cab_Burge]
#2248731
02/06/17 09:43 PM
02/06/17 09:43 PM
Posts: 12,401 Taxes & Virus's R-US, NY
Dragula
My old 400 block pump gas stroker motor made the most power with a set of 440-1 CNC ported by Jeff at MCH I tested two different motors with those heads and a set of Indy SR M.W. intake ports, the SR flowed 30 CFM less than the -1 did and the -1 heads made over 50 HP more than the SR heads did on the pump gas motor they made 65 more HP on the race gas motor Same short blocks, cams, intake and carb with no jetting or timing testing on either motor Go big for big power Really....50-60hp over the SR heads. I will have to look up and see where the EZ1 heads fall with respect to those...Mine flowed 330cfm at .700 if I remember correctly.
[Re: AndyF]
#2250046
02/09/17 12:09 AM
02/09/17 12:09 AM
Dragula
I've made over 900 hp with EZ heads so I don't see much reason to step up to the SR or -1 heads unless you already have them. You might want to look at header options to see what works the best. You shouldn't need more than a 2 inch header for the combo that you're building. https://www.youtube.com/watch?v=2zTAGAy081o Wasn't yours a dry sump?
[Re: Dragula]
#2250075
02/09/17 12:40 AM
02/09/17 12:40 AM
Thumperdart
State of confusion
Wasn't pretty, but it was unmolested and in very good condition...Gonna build a 440 source 512 this year out of it....
What heads (Indy) would you guys run in an A-body with 10.8:1 and just under .700 lift...I have EZ1 heads but was wondering if 440-1's would fit with my fender well headers and such... Nice and although I don't make gobs of power, my 400 has proven well for over 14 years................
[Re: Dragula]
#2250339
02/09/17 03:10 PM
02/09/17 03:10 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Gotta watch this... Similar build coming with much less head and in a street car...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Dragula]
#2252057
02/12/17 03:45 AM
02/12/17 03:45 AM
Cab_Burge
My M.W. unported SRs flowed 340 CFM @.700, the ported 440-1 flowed 370@ .700 on the same bench I didn't have a good set of dyno headers for the ported 440-1, the header flange protruded, blocked, into the lower exhaust port about 1/4 inch. They fit fine on the SRs but both motors I dyno tested the -1 heads started missing around 5200 RPM, it was a intermittent miss, not a steady dead cylinder miss It missed all the way up to and above peak HP RPM on both motors, the high compression race motor(526 C.I. 12.8 to 1 comp.ratio) missed worst than the smaller pump gas motor did (517 C.I., 10.8 to 1 comp. ratio)
[Re: Dragula]
#2332042
07/05/17 05:55 PM
07/05/17 05:55 PM
Thumperdart
State of confusion
I had to steel the Milidon pump cover off the Hemi....The old covers had a smaller inlet port than the new ones. I never knew that....Now the Hemi needs another new style cover as we had to adapt to the AN16 oil line. Always something.............
[Re: gregsdart]
#2332067
07/05/17 06:22 PM
07/05/17 06:22 PM
Dragula
The pulleys are for the alternator? Good luck at the track! Drives the water pump and alternator...Race car only stuff...lol What heads did you wind up with? Flow? Heads are my old try'd and true Indy EZ1 heads...330cfm at .600" is all they are...too scared to try 440-1's due to Header A-body fitment...Went 9.70 in my 440
