Re: Under car rearend Video
[Re: SpareParts]
#2248229
02/06/17 01:40 AM
02/06/17 01:40 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
28.10.5 track conditions were very poor that day... we had a tuff day but still managed to come home with a nice check...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2248236
02/06/17 01:52 AM
02/06/17 01:52 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
does it look like the tires start to unload a little bit about two to five inches out from the launch ?
[Re: WHITEDART]
#2248284
02/06/17 03:14 AM
02/06/17 03:14 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Cab has it right, this is far from smooth. Shocks are too soft on extension. If you freeze it at the hit, the sidewall is compressed to about half it's height. And the car is out a bit before it actually "stands" the tire up. All that is eating 60ft. It pounded the tire so hard, it was a whisker from blowing them off. Watch the video again. You nearly see daylight under left rear when it hammers, cups and rebounds.
[Re: Monte_Smith]
#2248340
02/06/17 10:49 AM
02/06/17 10:49 AM
Posts: 287 PA
Harry's Taxi 2
PA
What would be the shock setting to shoot for....no sudden separation/extension with minimal to no tire compression or just a slower separation with more tire pressure to minimize tire squash?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: misfired]
#2248377
02/06/17 12:19 PM
02/06/17 12:19 PM
WHITEDART
bean town ....Ca
Looks good, what was your tire pressure? Looks like time for radials to me....
Also any wheelie bars on your car? 13.5 was the air pressure..and no bars on car...I had a set of 275s pro in the pit...but I would have never got them to work that day...
[Re: Monte_Smith]
#2248387
02/06/17 12:36 PM
02/06/17 12:36 PM
WHITEDART
bean town ....Ca
Cab has it right, this is far from smooth. Shocks are too soft on extension. If you freeze it at the hit, the sidewall is compressed to about half it's height. And the car is out a bit before it actually "stands" the tire up. All that is eating 60ft. It pounded the tire so hard, it was a whisker from blowing them off. Watch the video again. You nearly see daylight under left rear when it hammers, cups and rebounds. I agree 100% with the shock needing more extension control... and actually started off that way... wrong or right we actually were able to get the car to go down the track this way.. track prep was non-existent for this import vs. Domestic shootout... with our normal shock settings the car would not even moved 1 inch before blowing the tire off.. Im still new at this and learning every day... appreciate your guyses input..
[Re: WHITEDART]
#2248436
02/06/17 01:34 PM
02/06/17 01:34 PM
Monte_Smith
North Alabama
Its just hammering the tire. It may simply need to be tighter on rear extension. But it may also need tighter front extension, an air pressure adjustment, weight bias change or all the above. All I know is what I see in that video and that is the tire is very unhappy. From previous discussions about the lack of 60ft from this car, I would say this is an ongoing issue.
If it will only work on a marginal track by punishing the tire as he alluded to above......the set up is off.
The thing about data and video, is that it is great to have, but you have to learn to use it. Guys also get caught up in a goal......lets say 60ft. BUT, don't worry about 60ft, until you go 30ft and don't worry about 30ft until you go 10ft. Fix the FIRST thing wrong. And in this case it's the way the car hits the tire. If you don't fix this, you will never fix anything else.
[Re: WHITEDART]
#2248448
02/06/17 01:52 PM
02/06/17 01:52 PM
Monte_Smith
North Alabama
Well, that remains to be seen, because as discussed above, this car is far from working very good. It has issues, which is why I suspect he posted the video.
The stacked spacers puts the leverage point well away from the spring. Maybe the shock is good enough to control pinion rise with the added leverage, maybe it's not. That remains to be seen
[Re: WHITEDART]
#2248467
02/06/17 02:17 PM
02/06/17 02:17 PM
Posts: 360 Ohio
shorthorse
Ohio
Can't or don't know how to do it with You Tube but if you have the original video, I found a free player called "media player home classic cinema" from https://mpc-hc.org/. You can slow a video down 10X. Works great for viewing launches.
[Re: WHITEDART]
#2248482
02/06/17 02:34 PM
02/06/17 02:34 PM
Posts: 10,032 MN
JERICOGTX
MN
Always nice to learn from this type of info.
69 GTX
68 Road Runner
[Re: Monte_Smith]
#2248528
02/06/17 03:37 PM
02/06/17 03:37 PM
WHITEDART
bean town ....Ca
[quote=Monte_Smith]Well, that remains to be seen, because as discussed above, this car is far from working very good. It has issues, which is why I suspect he posted the video. ..................... I think everyone that watches the video can tell my car is a piece of sh!t.. I never claimed to be the best or better than than anyone else... I already explained that I didn't think the shock settings were correct. But that's where I ended up that day.. to go A to B....
[Re: WHITEDART]
#2248543
02/06/17 03:50 PM
02/06/17 03:50 PM
Monte_Smith
North Alabama
Nobody said anything about your car being that. But you have posted several questions here, as well as putting up this video. Only trying to help you, based on what I see. If you would rather not have any more comments from me........I will gladly bow out, just say the word.
Trying to make a small tire leaf car 60ft hard is a tough job. You are doing fine, but there is definitely more there. In case you haven't noticed, I don't sugar coat things......LOL!!! Ask me what I see or think and I will tell you. I would rather hear things straight and that's the way I tend to give it. Some are not like that and I understand that as well. We are grown men, should be able to have a conversation and not take it personally..........because it's NOT personal. You don't know me, I don't know you.
[Re: WHITEDART]
#2248552
02/06/17 03:57 PM
02/06/17 03:57 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Snowflakes.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: WHITEDART]
#2248554
02/06/17 04:00 PM
02/06/17 04:00 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
I think everyone that watches the video can tell my car is a piece of sh!t.. I never claimed to be the best or better than than anyone else... I already explained that I didn't think the shock settings were correct. But that's where I ended up that day.. to go A to B.... [/quote]
Man, where you coming from? I don't think Monte was saying anything bad (Sh!t) about your car, all he said was that the owner knows that the car was far from working good and that is why you posted the video. Before you start pounding the keys on your keyboard, sit down and try to comprehend what people are trying to tell you.
Monte was trying to help.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: Monte_Smith]
#2248567
02/06/17 04:12 PM
02/06/17 04:12 PM
WHITEDART
bean town ....Ca
Trying to make a small tire leaf car 60ft hard is a tough job. You are doing fine, but there is definitely more there. In case you haven't noticed, I don't sugar coat things......LOL!!! Ask me what I see or think and I will tell you. I would rather hear things straight and that's the way I tend to give it. Some are not like that and I understand that as well. We are grown men, should be able to have a conversation and not take it personally..........because it's NOT personal. You don't know me, I don't know you. I didn't realize you were trying to help.🖒.. reading from your post and others here on this site have been a great help... thanks I'm going to make the move to the 275 Pro at the next race. I'm sure I will have many questions for you concerning that... I see a lot of the guys try to make the change at our local tracks.. and they are not successful.. I feel there may be a slight advantage to the tire and I want to make it work. I will probably a bunch of questions soon
[Re: Cab_Burge]
#2248589
02/06/17 04:51 PM
02/06/17 04:51 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
WD... Here's some that's solid...
[Re: WHITEDART]
#2248611
02/06/17 05:36 PM
02/06/17 05:36 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Your definitely moving in the right direction, I am sure you will keep picking away at it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: WHITEDART]
#2248697
02/06/17 08:46 PM
02/06/17 08:46 PM
Posts: 4,684 On the parachute mount
n20mstr
Listen to the man.......(Monte is a good source of info, and when you don't listen, you find out later he was correct ...lol )
It does look like too hard of a hit. Might actually work with a radial, but is that shock good enough to keep it down ? After the hit
What shocks are those, and they have too much shaft showing , especially for a leaf spring car
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2248745
02/06/17 09:58 PM
02/06/17 09:58 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Listen to the man.......(Monte is a good source of info, and when you don't listen, you find out later he was correct ...lol ) lol, yup.
[Re: dbran451]
#2248811
02/06/17 11:17 PM
02/06/17 11:17 PM
WHITEDART
bean town ....Ca
I think your car is bad running cal tracs and leafs watched a couple of your videos and was wondering what trans are you running since you are leaving at around 5k I run a two speed glide 3000lb..I leave the starting line between 5 and 6000 RPM depending on the track conditions..
[Re: VernMotor]
#2248816
02/06/17 11:27 PM
02/06/17 11:27 PM
WHITEDART
bean town ....Ca
Cool video it stayed hooked up the hole time...is that a tie down on the bottom of the housing?
