Transmission line question #2247816
02/05/17 04:06 PM
02/05/17 04:06 PM
morrisville, pa
skajm Offline OP
skajm  Offline OP
morrisville, pa
Hi All
What is the size of the transmission cooler lines? 5/16 or 3/8. This is for an 84 truck 727
Joe
Re: Transmission line question [Re: skajm] #2247826
02/05/17 04:24 PM
02/05/17 04:24 PM
I think all of those lines were 5/16"
Re: Transmission line question [Re: skajm] #2248082
02/05/17 10:46 PM
02/05/17 10:46 PM
scratchnfotraction Offline
correct 5/16" steel lines
trans brass fitting are 1/8" pipe x 5/16" flare
front port/line is pressure line out of trans to rad cooler
rear port/line is return from rad cooler to trans
Re: Transmission line question [Re: skajm] #2248429
02/06/17 01:27 PM
02/06/17 01:27 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Yes. It was 5/16 before the overdrive.
Re: Transmission line question [Re: skajm] #2249358
02/07/17 10:16 PM
02/07/17 10:16 PM
morrisville, pa
skajm Offline OP
skajm  Offline OP
morrisville, pa
Thanks you guys are the best
