Splined front sway bar set up for Mopars #2247471
02/05/17 12:04 AM
02/05/17 12:04 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Some people have asked, so here are some pics of the splined front sway bar set up on the Valiant. Obviously it takes some surgery on the k frame. I can take more pics if needed...
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247479
02/05/17 12:14 AM
02/05/17 12:14 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Details?
I've seen similar components at Speedway,, but never scoped it out enough to decide what might work.
Nice work too
Don't be the exception.
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247489
02/05/17 12:44 AM
02/05/17 12:44 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thats all the work of Tim Werner & AndyF (Finkbinder). I'm guessing the splined arm was bent in the middle to line up with the lower control arm. Definately helps with tire clearance. A friend of mine did something similar years ago on a Dart, as thats what they did on the kit/ Nascar cars.
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247532
02/05/17 01:47 AM
02/05/17 01:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I went perusing Speedway, no splined sway bar stuff like they used to have. Guess it's been a while since I thought about it.
Still a nice setup you have.
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247541
02/05/17 02:09 AM
02/05/17 02:09 AM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
If you sign up for the Mopax email list, Tim still lurks there. He was pretty good about answering questions about the car when I asked for info during my time owning it.
https://groups.yahoo.com/neo/groups/mopax/info
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247640
02/05/17 11:58 AM
02/05/17 11:58 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Off-road buggy/rock crawler build sites have quite a bit of what one would need to do a splined swaybar. I'd think between Anti-rock and Poly Performance you could pull together most of what you'd need to get one on a car.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247786
02/05/17 03:32 PM
02/05/17 03:32 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That looks clean and straight forward. If i can make out the geometry from the two posted pics, it terminates inside of the strut bar, which still remains the limiting point in tire width/backspace/turning angle, and not the sway bar bent lever?
It appears to be a hollow bar, 48 or 49 spline, and do you you know thew major/bearing diameter, and overall width, off hand?
I like the solution. up
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2247871
02/05/17 05:33 PM
02/05/17 05:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Coleman racing has a wide range of these also.
Mopar to the bone!!!
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2248230
02/06/17 01:42 AM
02/06/17 01:42 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
sway-away
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2248290
02/06/17 03:26 AM
02/06/17 03:26 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Different Speedway. Try looking up Speedway Engineering. I'm pretty sur that's who I bought tube and arms from. There's a couple of other sources as well, but that's a good one. On the '67 to 72? K it should work out in the stock mounting locations. Probably also for the early K. My recolection is Project V uses a 73 K which had a sway bar through it more like the kit cars did.
The hard part is getting the arm angle bent. The nice thing is once done, the geometry is set. Then changing rates is a matter of swapping tubes to different wall thickness.
Mine's not installed, its been on the todo list for too many years, but other stuff gets in the way (priorities).
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2248354
02/06/17 11:50 AM
02/06/17 11:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nah, I saw it at Speedway Motors, they still have a tiny bit of it there. They do a lot of circle track stuff, carry AFCO and Landrum items. But I think they stopped doing oval track stuff when Bill died.
I did see the Speedway Engineering site while I was looking this past few days. Ebay has a lot of surplus Nascar stuff too.
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2252972
02/13/17 03:40 PM
02/13/17 03:40 PM
AndyF Offline
AndyF  Offline
Yeah I remember that project. Tim did about 95% of the fab work on that splined bar setup. I just gave him a few ideas on how to do it and I think I machined up the bushings that hold the bar on each end.
Over the years that I worked with Tim he went thru a bunch of different bar designs on that car. The splined bar is just the logical place to end up after trying most everything else. Once you have a splined bar design then you can easily change the roll rate without spending a ton of money for custom bent bars.
Re: Splined front sway bar set up for Mopars [Re: AndyF] #2253638
02/14/17 05:50 PM
02/14/17 05:50 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I'd like to see splined sway bars offered for our cars... front and rear, all bodies A,B,E, etc. One potential problem for the front, whereby the bar passes through the K-frame, is the diameter... 1-1/4" ~ 1-5/16" gets to be pretty tight ... especially if the k-frame is the least bit slightly bent/crushed up... requires stretching the opening... not easy!... I've had to do it recently (installing a Firm Feel 1-1/4 hollow front sway bar... actually measures ~1-5/16" (larger than my solid 1-1/4 bar).
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2254237
02/15/17 09:43 PM
02/15/17 09:43 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Seems like you could sell a kit with the parts needed to weld it onto a k frame, but how many people would actually buy it?
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2254342
02/16/17 12:04 AM
02/16/17 12:04 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
If the price is close to what it would cost to put a front blade bar on my 911 it will be high. Yes this is not a Porsche but a factory GT3 front 5 way bar is $500 and a blade bar is $1650. Other aftermarket bars are about $500 also so is the cost benefit there. I would think only if your going for the last 1/10th at the nationals to justify the cost. This is NASCAR territory here and cost to go with it but if the cost was less. Maybe
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2254411
02/16/17 01:53 AM
02/16/17 01:53 AM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Pretty limited market, I think. How many people want to build a car like The Red Brick?
Re: Splined front sway bar set up for Mopars [Re: lilcuda] #2254749
02/16/17 09:25 PM
02/16/17 09:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
for the right price, maybe
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Splined front sway bar set up for Mopars [Re: NV69B7RR] #2254981
02/17/17 12:48 PM
02/17/17 12:48 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Limited market, yes somewhat. Expensive, for a retail proposition, yes, but not for a home brewed set up. The parts could be pulled together for around $350-400. Splined bar-$150, end links-$100, attaching hardware-$50, bushings-$25, mounting hardware-$25. So, $700-800 retail, which tells me you won't sell many to your basic grassroots enthusiast, but for a fab shop that builds complete cars, it could be a nice option that some may upgrade to.
Due to limits on K frame through holes, it may need to either A)section the K have a pass through tube welded to the remaining K to allow up to 2" access, or B) move it further forward to the front of the K. Since tube diameters and wall thickness can be varied, the longer link arms required for a forward mount can be overcome with larger bar diameter, unlike stock bar selections with limited diameters. You would be adding a small amount of weight and deflection.
I've thought about doing this for sometime, but its not a high priority for my personal use and I've already laid out the limitations of the retail side. I'm also laying out adaptations for GM upper control arms too, but it also has similar retail limitations within a limited market.
Re: Splined front sway bar set up for Mopars [Re: TC@HP2] #2255002
02/17/17 01:37 PM
02/17/17 01:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Shroeder? Bars, they do custom, little pricy.
Re: Splined front sway bar set up for Mopars [Re: jcc] #2255069
02/17/17 04:00 PM
02/17/17 04:00 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
For you boys with QA1 front ends, it's an easy modification. Just order the correct width bar and arms, you are off and running. No mods needed.
http://www.colemanracing.com/Sway-Bar-1-14-x-48-Spline-P3795.aspx
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
