Re: Does EFI body need heat insulator?
[Re: ahy]
#2247425
02/04/17 10:34 PM
02/04/17 10:34 PM
Posts: 22,727 Bitopia
jcc
Bitopia
, and typical efi injectors begin to have issues at higher temps/heat soak, under certain conditions like slant six port injectors, right next to the exhaust so IMO anything that reduces op temps, should be a plus.
