727 Steel Planetaries #2246974
02/04/17 01:49 AM
02/04/17 01:49 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Was there a more modern transmission that used a steel planetary housing that will fit my 727 out of a 73 C body? If so, will i need a matching annulus/sun gears from it also?
Re: 727 Steel Planetaries [Re: Hot 340] #2247244
02/04/17 04:25 PM
02/04/17 04:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 47RH diesel trans has a steel front planetary but it won't fit the '73 727 because the spline angle is different. There is (was) a board member who was machining the spline to fit the 727.
Re: 727 Steel Planetaries [Re: Hot 340] #2247262
02/04/17 05:28 PM
02/04/17 05:28 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I think that's what the lower end CRT/A&A steel planets are (they have better ones too). They are a broached late model planet.
Re: 727 Steel Planetaries [Re: Hot 340] #2247429
02/04/17 10:42 PM
02/04/17 10:42 PM
crabman173
crabman173
I have always just used the stock 4 gear units --RV trans usually have them but if you need all you can get Rick at A&A is the 727 master of the universe
Think all the others just buy parts from him maybe
Re: 727 Steel Planetaries [Re: ] #2248699
02/06/17 08:48 PM
02/06/17 08:48 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Ok. Thanks guys. I thought i could grab a set of steel planets on ebag for a cheap upgrade. Lots on there for the later transmissions.
