Motor mounts 318- 440 in E-body #2246723
02/03/17 07:05 PM
02/03/17 07:05 PM
Raleigh, NC
Y
Youngblood Offline OP
Y
Raleigh, NC
Putting a 440 based 493 in a '71 Cuda. Was told it was an original 318 car. What do I need to do for mounts? Schumacher?
Re: Motor mounts 318- 440 in E-body [Re: Youngblood] #2246730
02/03/17 07:15 PM
02/03/17 07:15 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I think all you need is big block motor mounts. I don't recall doing anything special years ago when I put a 440 into a 340 Challenger.
Scott
1969 Super Bee, 383/4 speed
Re: Motor mounts 318- 440 in E-body [Re: Youngblood] #2246768
02/03/17 08:10 PM
02/03/17 08:10 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
need bb motor mount brackets
5549 post on old board
Re: Motor mounts 318- 440 in E-body [Re: Youngblood] #2247720
02/05/17 02:14 PM
02/05/17 02:14 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
If your car is an original v8 car, then you will need 383/440 motor mounts and brackets. They are pretty common as 1966-1972 d/c-body car mounts are th same and it will bolt right in. You will also need a transmission for a big block as the small block ones have a diffrent bolt pattern on the bellhousing.
