1994 cummins trans ID and value #2246580
02/03/17 03:40 PM
02/03/17 03:40 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Back in 2002 I bought a wrecked 1994 cummins dually. It was for a project that never happened. It is the truck that appeared in the Alcoa wheel ads. It has an auto trans that was built by Dunnrite? I am a stick guy what trans model is it? What is its value? I have the lowering kit and complete frame from cab back including the dually Dana 80 with flipped mounts and c frame reinforcements. Value? I have the complete running 5.9 cummins value? It had 140000 miles on it.
I am cleaning out the shop and thought I should investigate values and maybe liquidate these space takers.
Real Men shift for themselves
Re: 1994 cummins trans ID and value [Re: 1DGEMAN] #2246595
02/03/17 04:03 PM
02/03/17 04:03 PM
Guitar Jones Offline
Well the trans is a 47RH. It was a two year only '94-'95 transmission behind the CTD and V10. The V10 had a different converter and governor calibration though. They aren't exactly easy to find without a quarter million miles on them. Do a google search and see what you come up with.
