spring perch question #224656
02/14/09 04:43 PM
02/14/09 04:43 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I am fitting a Dana into my Dart and making new front spring hangers with the holes a little higher and further back to lower the rear of the car.
What angle should i weld the perches, bearing in mind, the axle is out of the car.
My old axle the perches were 5 degrees down.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: spring perch question [Re: deaks] #224657
02/14/09 09:39 PM
02/14/09 09:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'd wait and get them set with proper pinion angle.
No telling where it will end up. You could set it to a factory angle, but, that may totally wrong for the new set up.
Re: spring perch question [Re: RobX4406] #224658
02/15/09 10:36 AM
02/15/09 10:36 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I'm thinking off tack welding the perches on at 5 degrees nose down, then drop the axle in place to get the car on it's wheels and taking the measurement from there, whilst checking the trans at the same time.
Mike
best 60ft 1.36
Re: spring perch question [Re: deaks] #224659
02/15/09 11:08 AM
02/15/09 11:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can set the rearend in the car like it would
be(where you want it), use stands and wedges to get
about 6* down from the tailshaft on the trans to the
pinion. Put a couple of good tac welds on. Once you
get the pinion angle you can hook up the springs.
The front really wont change the height of the car,
the rear of the spring does that
Re: spring perch question [Re: MR_P_BODY] #224660
02/15/09 11:17 AM
02/15/09 11:17 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
wouldnt the pinion* depend on the spring rate and TQ output of the engine at the pinion?i imagine it is complicated to figure mostly due to the front spring segment rate.i have never herd it mentioned. could you put a hyd jack with a psi gauge on the pinion and apply pressure to determine the angle #rate?
Re: spring perch question [Re: blownzoom440] #224661
02/15/09 11:23 AM
02/15/09 11:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure torque plays into itbut you have to start somewhere
and the way I use to check the pinion rap up was
using clay on the floor pan
Re: spring perch question [Re: MR_P_BODY] #224662
02/15/09 11:32 AM
02/15/09 11:32 AM
ELYRIA,OH
ELYRIA,OH
sorry if i over complecated an idea.
how would you keep the clay on the floorpan?determine how much?
Thanks for your input!
Re: spring perch question [Re: blownzoom440] #224663
02/15/09 11:43 AM
02/15/09 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I used a clean floor pan and then smeared clay on it
with my thumb to get a coated area (you can tell if it
will hold) then stacked up the clay on that area. Also
when doing this you need to take in to account the
body drop so I used tie raps on the shock
