shadetree engine flush
#2241175
01/25/17 07:11 PM
01/25/17 07:11 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Hi, I've got all the components off the front of my engine(440) and its still in the car. My question: With the water pump housing off, could I flush the engine by using a garden hose on one opening and the contaminated antifreeze would come out the other hole on the front of the engine?
Semper Fi
Re: shadetree engine flush
[Re: GOLDMYN]
#2241256
01/25/17 09:52 PM
01/25/17 09:52 PM
RapidRobert
My question: With the water pump housing off, could I flush the engine by using a garden hose on one opening and the contaminated antifreeze would come out the other hole on the front of the engine? yes but do the pair of block holes on each side as they are isolated (the top ones on each side come together into the center at the stat housing). You are thinking it is partly plugged so as said I would pull the freeze plugs & blast it out with a car wash wand but that would entail towing it there. EDIT & it'd be a good idea to stick the wand in the upper hole on each side to back flush
[Re: GOLDMYN]
#2243375
01/29/17 02:31 PM
01/29/17 02:31 PM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
I agree with topside and RapidRobert: open the drain plugs on each side of the block to be sure of flushing all of the old coolant from the engine. When I got around to seriously flushing my own block, I discovered that the drain on the block was completely plugged. After reading up on rad flushes, I ended up running 1 kg of citric acid through my engine to remove rust and scale. Citric acid is safe for iron, brass, and aluminum and my cooling passages now look like they were freshly cast. I did a write up about this for members of my car club: Cooling System
[Re: GOLDMYN]
#2243408
01/29/17 03:34 PM
01/29/17 03:34 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Since you are doing a thorough flush from the above advice. Follow it up with an impurity free fill.
Since the block will be left with garden hose water in it. Fill it with distill, drain and repeat a few times. This leaves the block for of distilled instead of garden hose water, even after a drain.
Then determine the capacity of your cooling system. Divide that capacity by 2. Add that amount of concentrated coolant to your system. This will then be a true mix of 50/50.
[Re: GOLDMYN]
#2246585
02/03/17 03:44 PM
02/03/17 03:44 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If the system is that dirty, go through with your flush (including block drains). Then, put the pump back on it and dump half a bottle of dishwashing detergent in the radiator. Top with water. Cap it and run the engine for 20-30 minutes.
The cap will prevent it from becoming a soap suds monster.
Drain and fill with your usual coolant mix.
[Re: RapidRobert]
#2246604
02/03/17 04:20 PM
02/03/17 04:20 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
[quote] blast it out with a car wash wand but that would entail towing it there. Robert , I see you as a beneficial member of this site, helpful and very knowledgeable. That said I must add; This is not exactly what I would consider a conscientious suggestion. Car wash owners hate this. So does the next person wanting to clean their car. It leaves greasy crud on everything. A large part of the reason so many have closed around here is the oil and grease contaminating the plumbing. Home use pressure washers are cheap and very handy to have.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2246660
02/03/17 05:51 PM
02/03/17 05:51 PM
RapidRobert
Alright, I wont recommend it again. (I had no idea that was problematic for the owners).
[Re: GOLDMYN]
#2246742
02/03/17 07:44 PM
02/03/17 07:44 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I always install one of these screens in the upper hose on these old cars, otherwise your radiator WILL get plugged up. LINK TO GANO UPPER HOSE SCREEN
[Re: CSK]
#2246804
02/03/17 08:56 PM
02/03/17 08:56 PM
feets
Senior Management
Senior Management
Irving, TX
I always install one of these screens in the upper hose on these old cars, otherwise your radiator WILL get plugged up. LINK TO GANO UPPER HOSE SCREEN If you're going to throw a kitchen strainer in there to plug up your hose you might as well install the proper thing.
[Re: feets]
#2246891
02/03/17 11:32 PM
02/03/17 11:32 PM
CSK
Pattison Texas
I always install one of these screens in the upper hose on these old cars, otherwise your radiator WILL get plugged up. LINK TO GANO UPPER HOSE SCREEN If you're going to throw a kitchen strainer in there to plug up your hose you might as well install the proper thing. WOW Feets, you are wrong, the set up I use works great. Typical that is a bypass filter, what happens to the unfiltered coolant with rust chunks to plug up the radiator.
