Which rear gear ratio? #2245865
02/02/17 01:27 PM
02/02/17 01:27 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Street trim Cuda with 528" Hemi, 500ft/lb at rear tire at 2k rpm, Tremic 5 sp with 2.87 1st, .64 5th, 27" tall tire, 8.75 rear with 489 case. Street car.
I'm thinking 3.91 or 4.10. On the RPM calculators I have found, I can't plug in trans ratio, only tire, rpm and rear gear.
Also, would you go with the Sure Grip or the Easton True Track?
Thanks!
Re: Which rear gear ratio? [Re: Dr Dave] #2245874
02/02/17 01:37 PM
02/02/17 01:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
4.10 with a Tru Track...You still may not use 5th gear a lot with a .64 ratio... twocents
...FAFO...
Re: Which rear gear ratio? [Re: Dr Dave] #2245915
02/02/17 02:37 PM
02/02/17 02:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
4.10 is too deep for that car. The 2.87 first gear would be incredibly short with that rear.
You'll be fine with 3.73 gears.
We put a Tremec in a car with 3.54s and it liked 70 mph more than 60 mph in 5th gear.
- Stu Harmon
Re: Which rear gear ratio? [Re: Dr Dave] #2245923
02/02/17 02:47 PM
02/02/17 02:47 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i would run 4.10 if you don't have short tires.
28" tire at 70mph with 4.10 gives you 2200rpm in fifth...
Re: Which rear gear ratio? [Re: Dr Dave] #2245968
02/02/17 04:24 PM
02/02/17 04:24 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The 4.10 is great in 5th but makes 1st useless.
Re: Which rear gear ratio? [Re: Dr Dave] #2245971
02/02/17 04:30 PM
02/02/17 04:30 PM
Dr Dave Offline OP
Dr Dave  Offline OP
I have 3.23's in it now. There is plenty of torque to pull that gear but thought a steeper gear would optimize the package.
Re: Which rear gear ratio? [Re: Dr Dave] #2245979
02/02/17 04:46 PM
02/02/17 04:46 PM
dogdays Offline
dogdays  Offline
So you have a 2.87 First gear. For years I have used an overall ratio of 10:1 for the First gear, as a calculation goal. 10 / 2.87 = 3.48. In a Dana 60 I'd use a 3.54 gearset. Ford 9" I would use a 3.50. 8 3/4 I'd use a 3.55.
That's just a rule of thumb but it has worked for me.
R.
Re: Which rear gear ratio? [Re: Dr Dave] #2245993
02/02/17 05:06 PM
02/02/17 05:06 PM
On your deal I would opt for the 3.91 up
I ran from 3.73 to 4.30 in my old pump gas Duster, it ran almost the same ET(10.30s) and MPH(127.) in the 1/4 mile at Woodburn. It seemed like it spent more time in high gear with the 3.73 but it ran almost the same shruggy
The stick tranny with the O.D. should still hook and book with the proper starting line RPM at the drags twocents It won't be easy to get it correct on the first pass but it is doable with some testing scope You can spin or bog on the starting line, your right foot will control that work
BTW, Yukon makes a 3.73 gear set for the 741 center section shruggy Those are the ones I used in my car up
Re: Which rear gear ratio? [Re: Dr Dave] #2246029
02/02/17 06:03 PM
02/02/17 06:03 PM
Kirkland, Washington
Pacnorthcuda Offline
I run a 3.55, 28" tire, 2.66 1st (or whatever 1st is in an 18 spline) in a warm 440.
In your car I would run either a 3.55 or maybe a 3.73 (if I could find one) with a clutch type sure grip and a solid spacer in that 489.
You have a LOT of bottom end, a low first gear and a medium height tire. I think with even a 3.91 you'll find 1st gear to be almost unnecessary.
You also risk ending up with noisier gears with a 3.91 than a 3.55.
Course nobody has asked you about how/where you drive, terrain ect. If your in the flats then definitely a lower numbered gear. if in the mountains then higher.
Re: Which rear gear ratio? [Re: Pacnorthcuda] #2246068
02/02/17 07:30 PM
02/02/17 07:30 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Pacific Northwest, like you!
Re: Which rear gear ratio? [Re: Dr Dave] #2246072
02/02/17 07:32 PM
02/02/17 07:32 PM
Dr Dave Offline OP
Dr Dave  Offline OP
I don't know if going to a 3.55 from a 3.23 is worth the time and effort. Thoughts?
Re: Which rear gear ratio? [Re: Dr Dave] #2246101
02/02/17 08:38 PM
02/02/17 08:38 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nope. Stick with what you have. You could always test something later.
Re: Which rear gear ratio? [Re: Dr Dave] #2246103
02/02/17 08:42 PM
02/02/17 08:42 PM
Chicago
PurpleBeeper Offline
Chicago
Dr Dave, as you can see the recommended gear ratios are all over the place. Why don't you decide for yourself? You can make the RPM calculator work for you like this:
1. Pick a rear end gear ratio to calculate on, say 4.10 for example.
2. Multiply that number by your overdrive ratio to get an "effective rear end gear ratio". In this case, 4.10 x 0.64 = 2.624
3. Use the standard RPM calculator to see what your rpm's would be with your tire diameter.
FYI - You can do the same sort of thing to get a feel for what your "shift point" would be in each gear at a reasonable rpm too. For example, with the same 4.10 gears and a 2.87 1st trans. gear you'd calculate like this:
a) 4.10 x 2.87 = 11.767 "effective gear ratio in 1st gear with 4.10's"
b) using your tire size, you can calculate a mph at a given rpm, say a 3000 rpm target shift point for daily driving, and see how many mph's you'd be going before you had to shift.
c) repeat the above with your other trans. gear ratios with a "target shift rpm" (like I just used 3000rpm) for the other gears to see how fast you'd be going in the other gears too.
Hope This Helps!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Which rear gear ratio? [Re: PurpleBeeper] #2246111
02/02/17 08:55 PM
02/02/17 08:55 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Really helpful, thanks!
Re: Which rear gear ratio? [Re: Dr Dave] #2246214
02/02/17 11:45 PM
02/02/17 11:45 PM
I've done it twice, it's noticeable, but yea, you could argue not worth the trouble.
Re: Which rear gear ratio? [Re: dogdays] #2246812
02/03/17 09:20 PM
02/03/17 09:20 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
This is good advice. Multiply the trans ratio and the rear ratio. Take the tire height into consideratio and make a choice.
Too low of a 1st gear is like having a truck with bull low.
Re: Which rear gear ratio? [Re: Dr Dave] #2246947
02/04/17 12:56 AM
02/04/17 12:56 AM
ky.
K
kenworth_goose Offline
K
ky.
I'D DO 4.30'S if it were mine. That thing would be a beast with them.
Re: Which rear gear ratio? [Re: kenworth_goose] #2247002
02/04/17 02:19 AM
02/04/17 02:19 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
With a big HEMI you are going to murder 27" tires on the street with any gear ratio. A gear set numerically higher than what you currently have will most likely make driving the car exponentially more exciting.
What kind of tire is on the car?
It seems like quite a few people have been surprised by similar ET's when they went up or down in rear end ratio either way.
Re: Which rear gear ratio? [Re: Dr Dave] #2247019
02/04/17 02:41 AM
02/04/17 02:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
For a street car that's not after every last tenth of ET, I like higher gear sets. I also don't mind a short smoke show 1st gear. Right foot input will control that on the street anyway. Stop and go traffic? That short gear will be happier on the clutch.
I had a TKO with .64 OD. I hated having RPM so low that 5th gear was useless below 65 mph. I went 4.56 and loved it. Tire frying through 3rd if I wanted to, yet cruise the highway at 70 mph at 2400 RPM.
**Photobucket sucks**
Re: Which rear gear ratio? [Re: Dr Dave] #2247040
02/04/17 03:41 AM
02/04/17 03:41 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I'm surprised nobody has mentioned that all factory 426 Hemi cars used the Dana when the 4 speed was used. You are now using an engine 102 cubes bigger with a smaller axle than stock?
