2006 Ram 2500 Trans woes #2245290
02/01/17 02:13 PM
02/01/17 02:13 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I got in my Ram the other day and when I shifted into drive and started out it clearly wasn't in first gear. It felt like it never shifted for the entire trip, and set off the check engine light. When I got home I hooked it up and threw these codes:
P0700 - Transmission Control System Malfunction
P0734 - Gear 4 ratio incorrect
P0876 - Trans Fluid Pressure Sensor/Switch D Ckt Rng/Perform
I am not by any means an auto trans expert, so what is going on here?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2245465
02/01/17 07:27 PM
02/01/17 07:27 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
A common issue on the 48re is the shift solenoid and or transducer fail. Symptom is that it starts out in 3rd gear. Usually replaced in pairs. I did mine with an upgraded borg warner solenoid. About $100 and a couple hours of work. Only need to drop the pan. I did a filter and flush at the same time. Adjusted the bands etc.
**Photobucket sucks**
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2245469
02/01/17 07:31 PM
02/01/17 07:31 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You are assuming it's a 48re. Is it a hemi or Diesel? It will be a RFE style trans if hemi powered.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2245521
02/01/17 08:48 PM
02/01/17 08:48 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Hemi powered
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2246485
02/03/17 01:23 PM
02/03/17 01:23 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Needs the solenoid pack replaced. Guess I'll flush it and change the filter, etc while it's open, too.
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2246527
02/03/17 02:33 PM
02/03/17 02:33 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Should be filters as in two.
Re: 2006 Ram 2500 Trans woes [Re: Erik] #2247160
02/04/17 01:32 PM
02/04/17 01:32 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
i put this on my 06 when i had issues, cured, more line pressure and better parts, http://www.ebay.com/itm/330472458987?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
