Anyone retro fit an electric in tank fuel pump? #2244989
01/31/17 10:45 PM
01/31/17 10:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I would like to use an in tank fuel pump in my 71 Charger I will be building. I am running a 383 with a six pack and I have a 3/8 fuel line. If anyone has a suggestion for a fuel pump or know of someone making a new tank with a pump, let me know. Thanks!
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2244990
01/31/17 10:46 PM
01/31/17 10:46 PM
GA
roadrunninMark Offline
GA
tanks inc.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245043
02/01/17 12:08 AM
02/01/17 12:08 AM
tucson az
frank Offline
frank  Offline
tucson az
Tanks Inc will have a complete kit for your car. I used one of their tanks for my 68 Charger. I've also used a retrofitted stock tank and installed an Aeromotive pump in it. In my opinion the retrofitted tank is a better way to go. I've had clearance issues with the tanks Inc setup. I have pics that would clearly show this but for some reason I cant upload them. Tanks by Rick does very good work for not too much more than Tanks Inc. A Walbro 255 should be fine for your application
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245052
02/01/17 12:19 AM
02/01/17 12:19 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Frank, can you send me pictures to my e-mail ?
garyscar@hotmail.com
Thank you!
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245110
02/01/17 02:01 AM
02/01/17 02:01 AM
tucson az
frank Offline
frank  Offline
tucson az
One thing I forgot to mention. The tanks inc tank has a nice sump built into the tank to prevent fuel pump starvation.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245120
02/01/17 02:22 AM
02/01/17 02:22 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Are these retro pumps fitted into the tanks any quieter than external electric pumps?
**Photobucket sucks**
Re: Anyone retro fit an electric in tank fuel pump? [Re: 70Cuda383] #2245140
02/01/17 02:56 AM
02/01/17 02:56 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I have the tanks inc setup in my challenger and am very happy with it. It is dramatically quieter than the old external pump I had.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Anyone retro fit an electric in tank fuel pump? [Re: blown340] #2245262
02/01/17 01:27 PM
02/01/17 01:27 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
As one of the few people who have had both the Tanks, Inc and Specatra tanks in the same vehicle, I will highly recommend the Spectra. Better fitment, better access to hose lines, much more accurate fuel sender.
The Tanks sender is a Ford unit and will not go to full with a full tank.
Craig
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245271
02/01/17 01:35 PM
02/01/17 01:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What external EFI pumps are you guys using that are so noisy? I've used the walbro units on two different vehicles, one being a 4cyl with stock exhaust and could not hear it when the engine is running.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245567
02/01/17 10:24 PM
02/01/17 10:24 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The Walbro external we used on the FSAE car was very loud. There are many easy in-tank options available today, it's a no brainer. twocents
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245824
02/02/17 11:56 AM
02/02/17 11:56 AM
Manitoba, Canada
Manitoba, Canada
How did you guys mount it? Did you use the supplied P-clamps and foam isolator sleeve? I find that very surprising because the walbro I put on a stock exhaust chrysler 2.2 engine was inaudible at idle. There are other options, however none match the ease of repair or replacement of an external.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2245934
02/02/17 03:14 PM
02/02/17 03:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The problem you are going to have is that no one makes an intank pump that flows a significant volume of fuel at low pressure. There are some low volume, low pressure pumps out there, but they barely pump enough to feed a healthy carbureted motor.
You are going to have to run a return style regulator with a properly sized return line. Any pump that does flow enough fuel does it at high pressure. Sure you can use a high pressure pump with high flow, but it will be heating your fuel all the time it is running. Some of the higher volume, high pressure pumps put the equivalent amount of heat into the fuels as two 240 watt light bulbs would. That's significant, but a lot of people do it on their non-PWI fuel systems.
I've been mulling this issue over for several years, and have finally come up with a solution for a high volume system that can easily support over 700hp, and will keep the fuel cool and air free at the same time.
Since you have a stock tank and a six pack induction, you could consider doing this too. Cut open an access hole on the top of your tank to match a filler plate that will seal it once done, install a properly sized Holley Hydromat and a Fuel lab 40402 low pressure 2 speed pump in there. Plumb a 1/2" feed and return line to a return style regulator. Trigger the high speed pump voltage using a throttle shaft mounted switch that activates the high speed voltage to the pump when the outboards begin to open. Done. No special fuel tank, no ineffective baffles or sumps and a solid supply of cool, air free fuel even at very low fuel tank volumes.
EFI cars have it made, as they can use the same tank set-up with a Pulse Width Modulated EFI pump and no return. Sweet, effective and moderately price.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2246456
02/03/17 12:17 PM
02/03/17 12:17 PM
Manitoba, Canada
Manitoba, Canada
Is fuel temperature really a problem for high hp fuel injected cars? The fuel is not going to be vaporizing in the lines at these pressures. So what if the fuel is a little warmer? It's going to get a lot warmer when it hits the intake valve.
Re: Anyone retro fit an electric in tank fuel pump? [Re: DaytonaTurbo] #2246581
02/03/17 03:40 PM
02/03/17 03:40 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Fuel expands when it is heated and contracts when it is colder. The thermal energy is denser in cold fuel than hot fuel. Air temperature affect the density of air as well. My car makes the most power with cold air and cool fuel. Remember Cool Cans?
Yes, the pressure of EFI systems keeps the fuel from vaporizing in the lines, but that doesn't negate the effect of pre-heated fuel on performance.
Properly designed fuel systems include adaptations to reduce the heat introduced into the fuel system as a result of high performance fuel pumps running at max output unnecessarily. It also adds to the life of the pump to run them at reduced output when max flow is not needed.
Fuel systems have really undergone some dramatic evolution in the past 5 to 10 years and not everyone is ahead of the curve, because of the pace of development. Its really cool for fuel.
Re: Anyone retro fit an electric in tank fuel pump? [Re: jbc426] #2246937
02/04/17 12:30 AM
02/04/17 12:30 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
JBC426,
Can you explain this more? If I look at the TanksInc website, the GPA-4 pump chart there indicates the pump can do 72GPH below 10PSI at 12VDC. Why won't that work with a high power carburated application? I understand you would need a return style regulator.
Re: Anyone retro fit an electric in tank fuel pump? [Re: davenc] #2247032
02/04/17 03:06 AM
02/04/17 03:06 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
JBC426,
That is one of the higher, low pressure GPH rated pumps I've heard of. I'm shooting for just over 700hp and the smallest pump I'd consider running flows 160 GPH, which the pump manufacturer claims will support 800 HP. The 10 HP per GPH formula they are using seems optimistic to me.
One thing to keep in mind is that the pump you are referring to will be running at max output at all times in a bypass system. This introduces heat and accelerated pump wear. One of the reasons I picked the pump I did was due to the two speed function of the pump. Fuelabs makes the pump, and it is their lowest output model.
Re: Anyone retro fit an electric in tank fuel pump? [Re: jbc426] #2247346
02/04/17 08:46 PM
02/04/17 08:46 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Interesting times we live in! It wasn't that long ago when "high-power" was over 500HP in street car!!
I know the regulator will drop down the effective flow, but I suspect the pump I mentioned would support 500HP carburated. Agree it will not meet a 700HP application.
I don't have any data to back it up but fuel gains a lot of heat from the carb. At WOT the fuel doesn't sit in the bowl that long, but I know the carb is pretty toasty if the motor is at WOT for any length of time.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2247531
02/05/17 01:46 AM
02/05/17 01:46 AM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
I installed a Walbro 255 in my tank last
summer.There popular with the 10sec.
Mustang crowd.
If you can't fab-up what you need.
Check out Tanks Inc.
Vapor lock issues no more.
Mike
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2379354
09/30/17 02:49 PM
09/30/17 02:49 PM
AndyF Offline
AndyF  Offline
I'm just finish up a project to mount an Aeromotive pump in the tank on my '65 Coronet. It wasn't an easy project. I couldn't do the welding but I know a guy who can TIG soda cans so he helped me out.
Re: Anyone retro fit an electric in tank fuel pump? [Re: GLR] #2379366
09/30/17 03:01 PM
09/30/17 03:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You have any sump or baffling in there to prevent the pump from sucking air?
Don't be the exception.
