Re: Need some help - Sending unit lock rings and gaskets/orings
[Re: 71TA]
#2247089
02/04/17 11:07 AM
02/04/17 11:07 AM
Posts: 2,601 Great White North
Furyman
Great White North
Never seen an O ring. The flat seal was used from 1957 to some models in 1978.Three part #'s ,1730096, 1948757 & 3404451 .Don't know the correct thickness for each one. The current repro lock rings that come with the majority of the senders are incorrect...not enough height so a thicker seal would be better.
"Long Live Mopars"
[Re: 71TA]
#2247151
02/04/17 01:18 PM
02/04/17 01:18 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
I'll have to snap a picture the O ring style was from a 73 Charger.
And the 2 lock rings I have, 68 B body and 73 B body, are both around .050" thick and they are rusty originals.
What are those part numbers Nigel? The seal?
[Re: tman]
#2247398
02/04/17 10:01 PM
02/04/17 10:01 PM
Posts: 2,252 New York
rarefish
New York
This seller claims NOS lock ring.
http://www.ebay.com/itm/142015687206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT I doubt that the ebay part is a NOS part. This is what I came up with. The lock ring and gasket on the left are the original factory parts from my 1969 Dart. The new lock ring and gasket on the right came with the reproduction Spectra Preminum fuel tank that I bought last year. I have measured and shown the thickness of the parts.
[Re: rarefish]
#2247472
02/05/17 12:06 AM
02/05/17 12:06 AM
Posts: 92 Iowa
Davtona
Iowa
http://www.ebay.com/itm/142015687206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT I doubt that the ebay part is NOS part. Why do you say that? What leads you to believe they are not NOS??
[Re: 71TA]
#2247493
02/05/17 12:50 AM
02/05/17 12:50 AM
rarefish
New York
Great info rarefish. What year/model is that oem setup from? 1969 Dart GTS 340
[Re: Davtona]
#2247499
02/05/17 01:01 AM
02/05/17 01:01 AM
rarefish
New York
http://www.ebay.com/itm/142015687206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT I doubt that the ebay part is NOS part. Why do you say that? What leads you to believe they are not NOS?? Well for starters. If it was still in the factory packaging. I would believe it more, but if you look closer at how wide the gaps are on the outer edge of the ring and compare it to the gaps on the factory ring. You will see the ebay one is a lot like the aftermarket one in my picture. The OEM one has a 3/4" gap and the aftermarket one has a 2-3/16" gap.
[Re: wannadrag]
#2247515
02/05/17 01:23 AM
02/05/17 01:23 AM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Thicker seal isn't the problem it's the lock ring. The lock ring is to thin and bends. And, when you figure that out then use a factory ring let's hope you've bought a good tank and it doesn't bent the tabs on the "new" tank... I remember on one occasion going out for a build's maiden voyage pulling over for a quick inspection and seeing a drip at the sending unit...I crawled under there and just touched the sending unit and the lock ring popped loose from it's position !!! Talk about panic strength to reseat the whole mess along the road...I figured I was going to be a roast toasty when the gas hit the hot exhaust... That's the last time I've used the cheapy lock ring on anything...
[Re: 71TA]
#2247811
02/05/17 04:00 PM
02/05/17 04:00 PM
71TA
Warren, MI
So I have a tank section and lock ring from a 68 B body and its .050" thick.
I'll have to pull the one from my own 71 Challenger and I may have to see if I can get a couple more like from a 62-65 B body.
If anyone is working on their car and has the gas tank out can you share a picture of the lock ring.
[Re: 71TA]
#2248403
02/06/17 12:53 PM
02/06/17 12:53 PM
Posts: 92 Iowa
Davtona
Iowa
The lock ring on Ebay http://www.ebay.com/itm/142015687206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT these were available from dealers until fairly recently.
Agreed these are NOS but later issue. Does anyone have a source for the correct 1969 style ring with the "shorter gaps"? I could use 3 of them NOS.
