BAD THROTTLE POSITIONING SENSOR SYMPTOMS #224513
02/14/09 02:51 PM
02/14/09 02:51 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
My 97 Dak, V6, when you shift, the rpm's go up, drop and if you hold the clutch in will go up and down, sometimes going up to around 2000, then eventually drop off. Idles fine when it finally settles down, sometimes the rpm's will stay up for quite awhile. I've had the throttle body off and cleaned it. Not really much difference.
It doesn't throw the check engine light on.
Is it the TPS or the IAC?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Magnumguy] #224514
02/14/09 03:21 PM
02/14/09 03:21 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Sounds like the IAC is hanging up, the TPS usually causes a 2-300rpm surge while driving at a steady speed.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: MoparJoe] #224515
02/14/09 03:30 PM
02/14/09 03:30 PM
S.E.Ohio
S.E.Ohio
It'll rev up and drop, but not what I call surging. I runs smooth, just up and down, eventually leveling out.
thanks
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Magnumguy] #224516
02/14/09 11:01 PM
02/14/09 11:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
TPS will cause a higher surging idle and also a hesitation like a bad accelerator pump does in a carb. Ron
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: 383man] #224517
02/15/09 12:01 AM
02/15/09 12:01 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
TPS's RARELY go south,though I'm not saying it's not that...check your pcv valve, maybe even pinch it off and drive it, see if it goes away. A pcv is after all a controlled vacuum leak. The other possibility is the intake pan.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: 10sec440] #224518
02/15/09 12:20 PM
02/15/09 12:20 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Dakota's have had a problem with the TPS for a long time. I had the surging issue on my R/T when I got it. Saw a post on the Dakota-Durango board about the TPS problem.
I talked to the Dodge dealer about it and they wanted to do all kinds of stuff. I asked about the TPS and they said they had never replaced one.
I replaced mine myself and the problem went away. My buddy in Nebraska had the same issue with his 2001 V-6 Dakota. Both ours are auto trans though.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: slantzilla] #224519
02/15/09 02:21 PM
02/15/09 02:21 PM
S.E.Ohio
S.E.Ohio
Thanks.
I wonder if there's not a way to test them.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Magnumguy] #224520
02/15/09 02:49 PM
02/15/09 02:49 PM
Park Forest, IL
Park Forest, IL
Thanks.
You should be able to connect an ohm meter to it and watch the sweep and check for dead spots I would guess.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: slantzilla] #224521
02/16/09 02:19 PM
02/16/09 02:19 PM
S.E.Ohio
S.E.Ohio
I'll probably go out and buy one, they're like $40. Probably eventually have to get one.
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Magnumguy] #224522
02/17/09 10:53 AM
02/17/09 10:53 AM
Ohio
Duster_Dude Offline
Duster_Dude  Offline
Ohio
From what you've described it sounds like the IAC has failed or is failing, that would make the RPM'S higher than normal. Just make sure you don't have any vacuum leaks, that's a good starting point.
TP sensors can cause all sort's of havoc. Their main characteristic is usually a hesitation like 383man said.
The best way I've found to check a TPS is via a DC voltage / waveform test.
Although, you have to have access to something like a Snap-on Vantage meter or a lab scope that shows waveforms.
But as long as you have a good multimeter, you can find out what each sensor is doing by reading the ohm's.
Here's a video I found that might help in your diagnosis....
http://www.wonderhowto.com/how-to/video/...l-motor-267188/
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Duster_Dude] #224523
02/17/09 11:44 AM
02/17/09 11:44 AM
S.E.Ohio
S.E.Ohio
thanks guys!!
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: Magnumguy] #224524
02/17/09 12:46 PM
02/17/09 12:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Sounds like you have the info to check and fix. Just wanted to add a little history.
Throttle position sensors used to commonly fail at a certain point, usually at less than a 1/4 throttle. What would happen is that the car would normally be driven at normal speeds and your foot would wiggle just a bit over the bumps. Since the sensor was similar to a fuel sending unit, the spot where all this took place would get rubbed down. They were fairly easy to check, you would just open the throttle slowly while watching the return voltage. It would raise normally, then drop out, then raise again. It would act like an ignition dropout or a fuel starve at that point. Fine above and below.
The AIS causes the idle speed waver. The early ones were pretty slow and tended high to avoid stalling. Newer ones are much better, but if you have a vacum leak or other issues causing the idle speed to be outside normal range, it has to work harder and learn to keep the idle normal. The factory tends to keep the throttle plates open during shifts, to match engine speed and to keep from closing and opening the throttle and dumping that enrichment fuel (emissions and MPG).
Re: BAD THROTTLE POSITIONING SENSOR SYMPTOMS [Re: RodStRace] #224525
02/25/09 01:32 PM
02/25/09 01:32 PM
S.E.Ohio
S.E.Ohio
Bought an IAC, problem solved !!!
