Are door locks and ignition different keys? #2244960
01/31/17 10:07 PM
01/31/17 10:07 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
It's been a long time since I drove an A-body (and I've been gradually building this one for 19 years!), so I cannot remember if my '72 has a separate key to get into the car (doors/trunk) and ignition?
I'm going to need new door and trunk lock cylinders anyway, because I don't think they're in the pile of parts that came with the car. Well, I have two door lock cylinders (from different Darts) and no keys except the ignition... whistling
Re: Are door locks and ignition different keys? [Re: DrCharles] #2244965
01/31/17 10:13 PM
01/31/17 10:13 PM
Texas
GTS440 Offline
GTS440  Offline
Texas
On all my stuff the ignition & door are keyed the same & the glove box & or console are keyed the same as the trunk.
Re: Are door locks and ignition different keys? [Re: DrCharles] #2244969
01/31/17 10:20 PM
01/31/17 10:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A good locksmith can re-key your existing door locks to work with your ignition key.
Re: Are door locks and ignition different keys? [Re: DrCharles] #2244971
01/31/17 10:21 PM
01/31/17 10:21 PM
West Plains, MO
West Plains, MO
Thanks smile
I found that Classic Industries (and probably others) sell a set of ignition + 2 door locks, all keyed the same. I was wondering about the trunk...
Re: Are door locks and ignition different keys? [Re: DrCharles] #2244982
01/31/17 10:33 PM
01/31/17 10:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Trunk used a different key originally.
There is at least one kit out there that changes that though.
Re: Are door locks and ignition different keys? [Re: DrCharles] #2244988
01/31/17 10:43 PM
01/31/17 10:43 PM
West Plains, MO
West Plains, MO
Thanks for the info. Hmm... what to do. Restoration Parts Source sells an ignition + 2 door lock set for a reasonable $38.45 shipped. I would bet it costs as much (if not more) to have my door locks re-keyed, and they'll still be 45 years old, too. work
Re: Are door locks and ignition different keys? [Re: DrCharles] #2245036
02/01/17 12:04 AM
02/01/17 12:04 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Every mopar I (or our family) had came originaly came with two keys per set. The round head is for trunk and glovebox (if keyed) and the pentastar is ignition and door locks. Pentastar first appears around 1968 IIRC, definately by '72.
Whether an aftermarket will wear or fail quicker than your old one is tough one to answer! So much of the new stuff is not so good to start with, so it depends on whether its a good quality repop as well as how much wear is in the originals. ??????
My own observation has been that keys wear quicker than the mechanism. And of the mechanisms, the ignition seem to get sloppy before the doors or trunks.
Not much to the lock cylinders. Might want to pull one and look at it. The pin cuts might even be marked on it.
Re: Are door locks and ignition different keys? [Re: Mattax] #2245055
02/01/17 12:26 AM
02/01/17 12:26 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Yep, nothing to them. The pins or tumbler aren't marked but can be determined from each other when laid side by side. Try to drop the pins and tumblers out as a set 1 at a time. In most cases I can take the pins & tumblers out of 2 or 3 sets and get enough of an assortment to build a cylinder, they will work properly even if you have 3 sets instead of the 5 from the factory. Fortunately due to being cheap and broke at 16 I learned how to do it years ago before I figured out I should be scared of such stuff, tore up a few in the process but get it figured out.
As started ignition and doors are the same trunk separate but matches console and glove box locks if equipped. Trunk locks are missing in many cases so I buy new, they're only like $12. The trunk key and ignition key are actually different base keys in most cases and so the keys wont even side in slot of the other. twocents
Careful, your character's showing!
Re: Are door locks and ignition different keys? [Re: mopar346] #2245070
02/01/17 12:43 AM
02/01/17 12:43 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is one thing I always like about my Darts, you have to lock the door with the key, so it was impossible to lock your keys in your car! up
JB Rhinehart, Realist
A-Body's RULE!
