Page 2 of 3 1 2 3
Re: Best Way To Cut 8AN Line [Re: cmcgee123] #224476
02/14/09 11:54 PM
02/14/09 11:54 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
by checking how sharp the blades are
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Best Way To Cut 8AN Line [Re: cmcgee123] #224477
02/14/09 11:55 PM
02/14/09 11:55 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
only 35.00
Nice !
but if i use those, how am i supposed to cut my fingers
Just use your second knuckle as the cut off mark, place finger on hose for length, insert both finger and hose into jaw, place bottom handle against bench, and press firmly against the upper handle with free hand. then go to wallace racing calculators to calculate potential Et savings being light one finger.
Re: Best Way To Cut 8AN Line [Re: dthemi] #224478
02/14/09 11:57 PM
02/14/09 11:57 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
makita 4 inch electric cut off wheel
1.39 9.85 - 137 mph
Re: Best Way To Cut 8AN Line [Re: dthemi] #224479
02/15/09 12:02 AM
02/15/09 12:02 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Wonder how many cuts it will make before the wires start bending over before cutting off?
Re: Best Way To Cut 8AN Line [Re: rowin4] #224480
02/15/09 12:03 AM
02/15/09 12:03 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I use electrical tape...then make my cut with cable cutters..
Re: Best Way To Cut 8AN Line [Re: rowin4] #224481
02/15/09 12:06 AM
02/15/09 12:06 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
use black tape ,tight on the line it will not fray apart
1.39 9.85 - 137 mph
Re: Best Way To Cut 8AN Line [Re: dthemi] #224482
02/15/09 12:06 AM
02/15/09 12:06 AM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
only 35.00
Nice !
has anyone done research to find which finger gives the most accurate measurments? with the most ET gained by removing said finger.
but seriously who makes those pliers?
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: Best Way To Cut 8AN Line [Re: cmcgee123] #224483
02/15/09 12:11 AM
02/15/09 12:11 AM
rowin4 Offline
rowin4  Offline
Just don't use the one you use to wipe your
Re: Best Way To Cut 8AN Line [Re: rowin4] #224484
02/15/09 12:17 AM
02/15/09 12:17 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Good advice...I stuck that particular finger in a hand held blender once...Made me realize just how right handed I am.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Best Way To Cut 8AN Line #224485
02/15/09 12:52 AM
02/15/09 12:52 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
only 35.00
That's what I use. They even work on your cigar in a pinch...
Re: Best Way To Cut 8AN Line [Re: Lefty] #224486
02/15/09 02:44 AM
02/15/09 02:44 AM
Cab_Burge Online work
Cab_Burge  Online Work
Two or three tight raps of duct tape and the finest tooth hacksaw blade I have, put the hose in a vise and saw away A real thin cut off wheel in a high rpm(23000+ ) four inch air powered dremel or grinder works well also as already siad
Re: Best Way To Cut 8AN Line [Re: Cab_Burge] #224487
02/15/09 03:41 AM
02/15/09 03:41 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I've used electrical tape and a Dremel with a cut-off wheel no prob.
Ride eternal, shiny and chrome
Re: Best Way To Cut 8AN Line [Re: DirectSubjection] #224488
02/15/09 05:07 AM
02/15/09 05:07 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
I use a big lead hammer on the concrete floor, and a sharp knife.
I lay the AN line on the lead, and then a sharp knife on top, and cut it with just one hammer blow, it will make a nice clean cut.
The braided steel, will need some massage to get round again.
I learned this method from a Top fuel racer.
I have heard cutting with a 1mm super thinn cut off wheel, also works great.
Never tried a plier tho.
Re: Best Way To Cut 8AN Line [Re: RT540] #224489
02/15/09 05:14 AM
02/15/09 05:14 AM
U.S.
moparniac Offline OP
U.S.
I used the plier ,method on 6an and it worked great. wouldnt cut the 8 n stuff.... reason for starteting this topic..
Mopar Performance
Re: Best Way To Cut 8AN Line [Re: rowin4] #224490
02/15/09 08:49 AM
02/15/09 08:49 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i use TP
Re: Best Way To Cut 8AN Line [Re: moparniac] #224491
02/15/09 08:51 AM
02/15/09 08:51 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
the small one i got from HD cut my 8 AN fine.
Re: Best Way To Cut 8AN Line #224492
02/15/09 09:25 AM
02/15/09 09:25 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
only 35.00
I don't even use tape when I use a cutter like this
Re: Best Way To Cut 8AN Line [Re: Cudafied] #224493
02/15/09 09:48 AM
02/15/09 09:48 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
only 35.00
I agree also, I have a large set that can cut up to #12 with no problem.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Best Way To Cut 8AN Line [Re: Plumb Wired] #224494
02/15/09 10:23 AM
02/15/09 10:23 AM
U.S.
U.S.
only 35.00
Mike Gray
where do you get a set like that
Mopar Performance
Re: Best Way To Cut 8AN Line [Re: moparniac] #224495
02/15/09 12:34 PM
02/15/09 12:34 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
only 35.00
Mike Gray
Grainger, McMaster Carr, sometimes hardware stores will have a nice set too.
Page 2 of 3 1 2 3
