Grand Cherokee noise #2244456
01/31/17 01:43 AM
01/31/17 01:43 AM
70duster340 Offline OP
My fiance's 2004 Grand Cherokee has developed a sort of thumping noise, which I thought was the CVS joint. I replaced the driver's side front CV assembly, and the noise was gone. Apparently that was short lived, since it has returned. The repair was done a week ago, so could I have misdiagnosed the problem?
Can anyone help me here?
Re: Grand Cherokee noise [Re: 70duster340] #2244712
01/31/17 03:07 PM
01/31/17 03:07 PM
Anybody???
Re: Grand Cherokee noise [Re: 70duster340] #2244736
01/31/17 03:27 PM
01/31/17 03:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What all have you checked? Could be tires,could be other side CV,could be wheel bearing. Lots of things it could be. Could even be loose lug nuts.
Re: Grand Cherokee noise [Re: 70duster340] #2245040
02/01/17 12:05 AM
02/01/17 12:05 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Did you check the CV joint at the transfer case side of the front driveshaft? They are prone to have boot failure and wear out quickly after this happens.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Grand Cherokee noise [Re: 70duster340] #2253372
02/14/17 03:31 AM
02/14/17 03:31 AM
Located the problem. Was the u-joint on the front drive shaft. Replaced the part, problem solved!
